![]() | Home > Technical (L322) > Changed spark plugs... But one... |
Cloned earl Member Since: 28 Jan 2014 Location: Earls Colne Posts: 12 ![]() ![]() ![]() |
Looks like a washer for the cam cover, when i changed the cam gaskets one of the washers fell off and fell nicely and neatly down onto the spark plug.. looks exactly like your photo... to get the washer out i drilled 3 holes in it and with some strong steel cable managed to 'spin up and out' after about 2 hours of trying other methods (vacuum cleaner etc). Mine was mad worse by the fact that the port was all filled up with oil due to the gasket leak!!, changing the gasket on the other side only took 35 minutes. Previous LR's
Mmmmmm dat gaat een heel gepeuter worden ben ik bang.
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 ![]() ![]() ![]() |
If it is just a washer over the plug - I have not been following the whole thread very closely - then two wooden coffee stirrers from Costa (other coffee sellers are available), a dab of Araldite on each stirrer, down the hole to contact the washer and nothing else, and retire for 24 hours before removing the stirrers and washer.
I thought of the glue route as well but am worried that the glue goes into places where it should not go. Then again, the welding rod route is similarly tricky ;( MY 2010 5.0 SC Galway green and sand interior!!
Is the washer moving when you push it ???? If there is some movement, you may try either compressed air from a BIG compressor (pressure and flow to be high) or a high pressure washer (Karcher) and see if they work the damn thing loose and blow it out.............. MY 2010 5.0 SC Galway green and sand interior!!
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
It's probably been pushed hard down into place when putting the plug lead back on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35860 ![]() ![]() |
take no notice of these silly suggestions, use one of these,
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Good blast of compressed air try and get underneath it and blow it out |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Tx for all your thoughts guys! Don't think the grabbing tools have enough room on the sides to get a good grip, actually I'm sure.... There MAYBE is about 1mm of space around... So it is really stuck in there... no movement, at all... Tried a steel pointy pick tool without any luck...
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 77 ![]() ![]() ![]() |
Could you drill a small hole in each side and screw a small self tapping screw in each hole, then you may be able to pull it out with some pliers |
I like that idea |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Having broken the tops (ceramic bits) off spark plugs in the past on other cars, this still leaves the hexagon with which to undo the plug? As you are replacing the plugs anyway? Unless things are very different on a petrol FFRR....I know it is a bit destructive but as a last resort..... .
True that Joe... No need to be to scary...
Sorry... Double post 2002 L322 V8 |
