Home > Technical (L322) > Changed spark plugs... But one...
Page 3 of 4 <1234>
johnboyairey
If it's one of the stepped washers from the rocker cover, then, if you grasp the inner up facing tube, you will pull it out. So trying to get round the outer ring maybe not necessary. Try using pliers.
Post #378101 18th Mar 2016 12:07am
Cloned earl
England 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Looks like a washer for the cam cover, when i changed the cam gaskets one of the washers fell off and fell nicely and neatly down onto the spark plug.. looks exactly like your photo... to get the washer out i drilled 3 holes in it and with some strong steel cable managed to 'spin up and out' after about 2 hours of trying other methods (vacuum cleaner etc). Mine was mad worse by the fact that the port was all filled up with oil due to the gasket leak!!, changing the gasket on the other side only took 35 minutes. Previous LR's
Series III x2 SWB
Defender V8 90
Range Rover Classic V8 3.9 x2
Range Rover Classic V8 3.5 efi
Defender TDI 300 x2 90/110
Freelander V6
Defender TD5 110
Discovery II V8 LPG
Post #378121 18th Mar 2016 8:35am
ebajema
Mmmmmm dat gaat een heel gepeuter worden ben ik bang.
First try magnets, needle nose pliers, tweezers (pincet) etc. If that doesn't work the next step could be more elaborate tools. Have you tried to see if the ring is magnetic.
Maybe you can make some hooks from old dentist hooks. They are quite strong, grind of the end and see if you can get them underneath at 3 positions approx. 120 deg apart. And than slowly pull up.
If you know someone with a welding machine you could try to weld three thin welding rods onto the ring and try to pull it out. The trick is to "spot weld" the welding electodes to the ring as in a bad start of welding. That is quite drastic and risky but could work. Make sure the battery is disconnected !!
Last option, just leave the bloody thing in and live with it until you start getting misfires.............. MY 2010 5.0 SC Galway green and sand interior!!
Post #378124 18th Mar 2016 8:54am
gbmud
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
If it is just a washer over the plug - I have not been following the whole thread very closely - then two wooden coffee stirrers from Costa (other coffee sellers are available), a dab of Araldite on each stirrer, down the hole to contact the washer and nothing else, and retire for 24 hours before removing the stirrers and washer.
Chris
Post #378128 18th Mar 2016 9:08am
ebajema
I thought of the glue route as well but am worried that the glue goes into places where it should not go. Then again, the welding rod route is similarly tricky ;( MY 2010 5.0 SC Galway green and sand interior!!
Post #378138 18th Mar 2016 10:33am
ebajema
Is the washer moving when you push it ???? If there is some movement, you may try either compressed air from a BIG compressor (pressure and flow to be high) or a high pressure washer (Karcher) and see if they work the damn thing loose and blow it out.............. MY 2010 5.0 SC Galway green and sand interior!!
Post #378146 18th Mar 2016 12:19pm
jonnyboy54321
It's probably been pushed hard down into place when putting the plug lead back on.
Looking at the setup, what about some angled pliers, with the handles like these?
http://www.irwin.com/tools/pliers-adjustab...re-crimper
Looking at your picture you have some working room to the right of the plug itself where you could get down into the recess? Handles would have to be in vertical plane to work though (as per the Irwin picture) 2007 Vogue TDV8 with 255/55/20's fitted
Post #378187 18th Mar 2016 5:28pm
take no notice of these silly suggestions, use one of these,
Post #378190 18th Mar 2016 5:39pm
holidaychicken
Good blast of compressed air try and get underneath it and blow it out
Post #378195 18th Mar 2016 5:49pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Tx for all your thoughts guys! Don't think the grabbing tools have enough room on the sides to get a good grip, actually I'm sure.... There MAYBE is about 1mm of space around... So it is really stuck in there... no movement, at all... Tried a steel pointy pick tool without any luck...
I'm also a bit afraid of going down the glue road....
Drilling some small holes and using a steel cable to try and lift it also sounds like a good idea..
Maybe tomorrow -if the weather lets me- I will try the compressed air... Keep you guys updated!
If all methodes fail I will try your suggestion Stan Thumbs Up 2002 L322 V8
Post #378228 18th Mar 2016 9:08pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Could you drill a small hole in each side and screw a small self tapping screw in each hole, then you may be able to pull it out with some pliers
Post #378231 18th Mar 2016 9:23pm
holidaychicken
I like that idea
Post #378277 19th Mar 2016 12:18am
Having broken the tops (ceramic bits) off spark plugs in the past on other cars, this still leaves the hexagon with which to undo the plug? As you are replacing the plugs anyway? Unless things are very different on a petrol FFRR....I know it is a bit destructive but as a last resort..... .
Post #378415 20th Mar 2016 1:48am
pietertje
True that Joe... No need to be to scary...
Also like the idea of the small hole and the self tapper to pour that ring out...
I need another day of good weather- and some spare time!
Keep you guys informed...
Thanks for everyones thoughts and tips Thumbs Up 2002 L322 V8
Post #378567 20th Mar 2016 9:21pm
pietertje
Sorry... Double post 2002 L322 V8
Post #378569 20th Mar 2016 9:23pm
Page 3 of 4 <1234>
