![]() | Home > Technical (L322) > TD6 WARM/HOT START PROBLEM... |
To start with (excuse pun) you need a new thermostat - hours of fun to fit |
rangeroveruk1 Member Since: 22 Mar 2016 Location: rugby Posts: 7 ![]() ![]() ![]() |
Hi Joe90 , as its my first post I will ignore the pun |
Probably best to look at replacing both 'stats while you are at it. My experience was that I sorted the main 'stat then a few weeks later was back to change the EGR 'stat. In terms of removing the EGR 'stat, my vote is against. But others have had some success. (I have however been running for several years without the "vicious" fan in place |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
This should point you in the right direction |
Ok latest update for anyone who may be interested.... |
Did this fix the temperature gauge issue too ?? .
Is your "Air Leak" the EGR by pass / blank? only its right in the area that you say the noise is and it has been disturbed recently |
Thanks for the reply but it's definitely not the egr blank as I can hear the noise when the engine isn't running , just the fuel pump priming |
Are you sure that it's engine related and not the FBH, they can make lots of whistling whooshing sounds, and can come on at anytime. Although it's not that exact area of the engine bay it is the correct side of the car, and could be doing a first class ventriloquists act of throwing the sound |
reidy99 Member Since: 27 Feb 2016 Location: suffolk Posts: 5 ![]() ![]() ![]() |
I am having the same problem replaced the high pressure pump and it was OK now 2 weeks later the problem is back but worse than before any other ideas to try? |
