Home > Technical (L322) > TD6 WARM/HOT START PROBLEM...
rangeroveruk1
United Kingdom 2003 Range Rover HSE Td6 Java Black
I know that this question has been asked a lot over the past... has anyone actually figured out what the issue is? I've been having issues for the last year or so... car starts fine in the morning but after any run it turns over but wont fire up, battery goes flat then I put a booster pack on and it will start...the strange thing is it during the winter the problem seemed to go completely ... but now its back! also the car never really gets warm, temp needle goes just past the blue and sometimes makes it a bit further but never to 12 o'clock... Ive got an EGR blank fitted ...
Leak back test done, no problems
Fuel temp sensor replaced
Cam pos sensor replaced
Ive just ordered a new fuel filter, inline fuel pump and the gasket/washer for the HP pump... any other ideas would e more than welcome..
Post #378876 22nd Mar 2016 2:53pm
To start with (excuse pun) you need a new thermostat - hours of fun to fit Laughing
Most with the starting problem seem to have eventually solved it by tackling to fuel pump in the tank or the secondary one under the covers near the LHR wheelarch.... .
Post #378912 22nd Mar 2016 6:39pm
rangeroveruk1
Hi Joe90 , as its my first post I will ignore the pun Laughing anyway that was going to be my next job .... What about removal of the EGR thermostat?
Post #378915 22nd Mar 2016 6:48pm
Probably best to look at replacing both 'stats while you are at it. My experience was that I sorted the main 'stat then a few weeks later was back to change the EGR 'stat. In terms of removing the EGR 'stat, my vote is against. But others have had some success. (I have however been running for several years without the "vicious" fan in place Wink ) .
Post #378952 22nd Mar 2016 9:21pm
miggit
This should point you in the right direction Thumbs Up http://www.fullfatrr.com/forum/topic33098.html Yesterday I couldn't spell Engineer... Today I are one!
Post #378983 23rd Mar 2016 12:46am
rangeroveruk1
Ok latest update for anyone who may be interested.... Wink replaced the fuel filter and the secondary fuel pump... Car seems fine!! But.... I did notice what I can only describe as "air leak" noise coming from the area of the fuel filter and the high pressure pump.. I can't pinpoint where it is coming from, it's there when you turn the ignition on I guess something to do with the fuel lines being pressurised, but no fuel leaks! any idea?
I have got a replacement gasket for the HFP but haven't fitted it yet...
Post #379652 27th Mar 2016 4:04pm
Did this fix the temperature gauge issue too ?? .
Post #379657 27th Mar 2016 4:45pm
miggit
Is your "Air Leak" the EGR by pass / blank? only its right in the area that you say the noise is and it has been disturbed recently Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379691 27th Mar 2016 10:56pm
rangeroveruk1
Thanks for the reply but it's definitely not the egr blank as I can hear the noise when the engine isn't running , just the fuel pump priming
Post #379717 28th Mar 2016 8:47am
miggit
Are you sure that it's engine related and not the FBH, they can make lots of whistling whooshing sounds, and can come on at anytime. Although it's not that exact area of the engine bay it is the correct side of the car, and could be doing a first class ventriloquists act of throwing the sound Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #379729 28th Mar 2016 9:37am
reidy99
England 2003 Range Rover Vogue Td6 Oslo Blue
I am having the same problem replaced the high pressure pump and it was OK now 2 weeks later the problem is back but worse than before any other ideas to try?
Post #380366 1st Apr 2016 7:32pm
