Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 7 of 20 <123 ... 678 ... 181920>
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
i prefered the look of the flatter faced one Thumbs Up
Post #376552 9th Mar 2016 4:36pm
Seems like lots of places are making head units to fit now, curved, straight, Android, WinCE, the list goes on and on... they will all be pretty much the same to fit though...
Pay your money and take your pick...
If I was doing it now I think I'd get a generic double din unit and a fitting kit that fills the space in at the side... some of them have all sorts of extras and are much cheaper than the fitted ones.... Thumbs Up Pete
Post #376569 9th Mar 2016 6:50pm
miggit
Whistle But you wont get the can bus to talk so the steering wheel option is out the window Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #376573 9th Mar 2016 7:12pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
android unit
so whats the best option and make to buy please 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #376771 10th Mar 2016 8:40pm
Depends what you want it to do and how much you want to spend....
I'd get one with DAB or the ability to plug in a DAB unit... it's really up to personal choice they all seem to be very similar in fitting... Pete
Post #376774 10th Mar 2016 8:53pm
boatsandy1966
cheers for reply id like to spend around 1k in total any recommendations ? dab sounds good 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #376775 10th Mar 2016 8:56pm
Shocked Shocked They are only a couple of hundred quid....
try this for starters...
http://www.ebay.co.uk/sch/i.html?_odkw=e53...p;_sacat=0
Just look for the spec you want... quad core is the fastest at the moment, the non android ones can be a bit slow in use but not real bad...
They seem to be up to Android 4.4.4. as the highest spec...
Make sure it comes with GPS software, some don't and it then cost's you more to buy it....
Thumbs Up Thumbs Up Pete
Post #376777 10th Mar 2016 9:03pm
boatsandy1966
cheers il have a look and get one just need a company to fit then 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #376798 11th Mar 2016 12:44am
PaulB1976
England 2004 Range Rover Vogue Td6 Bonatti Grey
Well.........Its in !
Huge thanks to Master Haylands for this post and to all that contributed to it.
Very pleased with the results, Only problem, Steering wheel buttons are not working so unsure if its a faulty canbus system?
Any ideas ?
Also, have a slight buzz/rumble out of a couple speakers (Guess they are blown), should i upgrade or buy like for like from a breakers?
Anyways, If i can follow these instructions, anyone can !!!! The hardest part really is removing all the trim !
Post #379887 29th Mar 2016 10:18am
Check you have connected the correct wire in the boot to the can bus, there are several similar coloured wires, "Canbus to the green wire from unit,connect to the white/slate(grey)/yellow wire in pin 9 in the radio plug"
There is a setting for steering wheel keys, does nothing on mine as they just work but maybe they need programming on different units...???
The speakers are 8ohm which is why you can run them doubled up on the 4ohm output from the unit, so whatever you get I'd get 8ohm ones...
And well done for getting it in, hope the few niggles get sorted OK Pete
Post #379898 29th Mar 2016 11:15am
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
I've just ordered my kit
am i missing the part of how to connect the FM aerial? it comes with an adaptor i see but the connector is in the boot and the aerial connection is up front in back of android unit so how does it reach all that way to connect up as the 5m extension is just speakers and power? Cheers!
Post #380962 6th Apr 2016 9:21am
Says it in there somewhere, you need a 5mtr aerial extension lead... loads on ebay.... Thumbs Up Thumbs Up Pete
Post #380989 6th Apr 2016 2:27pm
Ohwhatalad
thanks pete, my kit turned up today, suprisingly quick as it came from Germany.
think i have everything i need ready to start the process, but i do see the subwoofer doesnt get connected, what wire colour is the sub if you know? i think ill run a set of phono cabales to the back and buy an amp to run the sub but i just dont know which wire colour it is
cheers Thumbs Up
Post #381738 11th Apr 2016 11:55am
miggit
The sub output is on the green (ish) coloured phono plug.... there is no direct drive for the sub and it will require a stand alone amplifier to run it...... so that's one of your phono's used up Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381779 11th Apr 2016 6:01pm
There are a lot of wires going to the sub... easiest would be to follow them to the sub itself and see what's going on, it'l be down to two wires at the speakers themselves....!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #381786 11th Apr 2016 7:12pm
