![]() | Home > Technical (L322) > Driver seat ECU? |
kineavy Member Since: 21 Dec 2015 Location: Cambridge Posts: 33 ![]() ![]() |
I have just encountered the very same issue minutes ago. I have no drivers seat adjustment at all and the steering wheel had lost it's movement also. I have not checked anything yet but a point in the right direction would be a big help. |
geordiefella Member Since: 06 Dec 2013 Location: Lincoln Posts: 11 ![]() ![]() |
I would start by checking fuses 20 & 23. (30a & 7.5a)
Fuse 20 has blown. Went to replace it and it blew straight away. Any suggestions. |
Did you move either the seat or the steering wheel or did it blow without touching anything? |
Blew as soon as blades made contact in the fuse holder. Short under seat I reckon. All because I let swmbo drive and adjust the seat. |
Haha, yeh that's how mine started too!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
Geordiefella,
Hi Craig
But did you follow the correct procedure? Allowing the car to go to sleep first etc etc??? Even then, I’m not sure if 1hr would be long enough sir... Can you try a hard battery reset? |
Ive not found any definite stuff regarding the hard reset, i take it you mean short the +ve & -ve leads together after allowing srs to discharge?
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 ![]() ![]() ![]() |
Hi - you don't say what MY your vehicle is. I've got an 07 which had steering wheel adjustment issues. Whizzing the seat out is fairly easy and once removed from the car, you get good access to all the electronics, etc. that are likely to be causing the issue. Incredibly the connector had pulled out for my steering wheel caused by (I suspect) incorrect fitting when the seat was previously removed. If you've got a decent mulitmeter and RAVE circuit diagrams to hand, fault finding isn't too bad. On an 07-09 MY, the common point is the seat control ECU which is mounted alongside the offside runner on the drivers seat. Regards, Chris |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Did either of you find the fault? |
