![]() | Home > Technical (L322) > L322 2004 V8 - difficulty starting when warm |
Is this only happening when the engine is warm or does it also have starting issues when cold ?
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
Ebajema - thanks for your reply! It's never been a problem when cold!! I'll look into the other suggestions. |
At least that limits the potential problem areas. May I suggest to also look at BMW forums and see if this type of issue also happens with the 4.4 V8 in BMWs ??
The pump was a new one, but I can't actually remember if I was having this issue beforehand or not. I've just been out and tried it - it's been standing for about 2 hours which would normally cause the issue. There was no smell of fuel so I tried waiting like you suggested (about 30 seconds) and it started fine. I'll keep trying this to see if it works every time. Will keep you posted!
Glad the longer wait seems to do the trick, not that it helps you with finding the cause though. Good to hear there seems to be no leakage though. MY 2010 5.0 SC Galway green and sand interior!!
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I have had this same warm starting issue in the past, turned out that it was the fuel filter (located under the removal panel near the fuel tank) has a couple of clip on fuel pipes. I replaced it and my issues instantly went away and have never had any starting issues since
Mattstevenson2005 - aha! Something else to check, thanks |
Checked the filter and remembered I'd changed it at same time as fitting new pump. One thing I did notice: the Schrader valve on the fuel rail was a little loose so tightened it up! Will see if this makes a difference. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
Had this issue as well after putting in a new fuel pump.Wasnt the pump or the filter or loss of pressure at the fuel rail.It was the camshaft position sensor on bank 2 which was acting up.Diagnosed by my mechanic. |
The loose Schrader valve could make a difference although I'd still expect it to be acting up when cold as well. Maybe it is when cold that it gets just a little more time to build up pressure |
It hasn't been as bad since tightening the valve, but does occasionally sound as though it's not going to run - ie it doesn't rev up at all. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Just keep looking for the suggested markers. A small crack seems the most logical reason. Have you looked around the Schrader valve if there are any signs of petrol leakage ? Maybe it came loose because there is a little crack in the fitting that allows it to loosen ?? MY 2010 5.0 SC Galway green and sand interior!!
Today the weather is really warm (25 dregs in May is hot). First thing this morning started fine. Drove 3 miles and parked up for 5 hours, left in full sun, started fine. Drove 3 miles home and left for 10 mins - really difficult to start! So worse the hotter the ambient temp.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8631 ![]() ![]() ![]() |
Could be worn injectors, you switch off and they leak and dump fuel into the engine, won't start well until it has all evaporated as it floods the engine... before fly by wire you could crank it with a WOT to clear it but I don't know if that would work...!!!
