![]() | Home > Technical (L322) > brake lights stuck on |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
i had a similar issue on an Audi I had some time ago and it was a sticking microswitch in the brake pedal mechanism. A quick squirt of light oil sorted it. Worth a look I guess. Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35763 ![]() ![]() |
talked about a while back and i seem to remember it was due to a flat'ish battery.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Light control module is behind the bonnet pull panel, these either get wet of just fail! This will most likely be your problem...
mark g Member Since: 28 Dec 2015 Location: Shropshire Posts: 31 ![]() ![]() ![]() |
thank you craig, the module was stuffed, you were bang on once again, thanks very much, mark. |
bigdave1947 Member Since: 03 May 2015 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
Hi my LCM is I assume duff as I have had lots of light problems so I bought a brand new one but when connecting it I get a EPROM LCMC error. Reading about this it says the unit must be synchronised by using texbook/T4. I phoned up local main dealers who seemed to have no idea what to do? any suggestions? regards Dave |
