Home > Technical (L322) > brake lights stuck on
mark g
United Kingdom 2004 Range Rover Vogue Td6 Java Black
my brake lights are still on after i have locked the car, if i unlock the car and start it they behave normally, i have plugged in my diagnostic kit and cant find anything so have disconnected the battery to stop it from draining, i have recently fitted a towing kit its the westfalia oem one could this be the issue? unplugged the towing loom but it didnt make any difference, thanks for any pointers, mark.
Post #382020 13th Apr 2016 6:30pm
Arch Stanton
i had a similar issue on an Audi I had some time ago and it was a sticking microswitch in the brake pedal mechanism. A quick squirt of light oil sorted it. Worth a look I guess. Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #382029 13th Apr 2016 7:54pm
talked about a while back and i seem to remember it was due to a flat'ish battery.. ... - .- -.
Post #382030 13th Apr 2016 8:00pm
Light control module is behind the bonnet pull panel, these either get wet of just fail! This will most likely be your problem...
Take the LCM out and check the unit & electrical plug for water ingress issues sir Thumbs Up
Post #382037 13th Apr 2016 9:06pm
mark g
thank you craig, the module was stuffed, you were bang on once again, thanks very much, mark. Bow down
Post #382894 19th Apr 2016 7:14pm
Post #382954 20th Apr 2016 10:26am
bigdave1947
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi my LCM is I assume duff as I have had lots of light problems so I bought a brand new one but when connecting it I get a EPROM LCMC error. Reading about this it says the unit must be synchronised by using texbook/T4. I phoned up local main dealers who seemed to have no idea what to do? any suggestions?
regards Dave
Post #409299 14th Oct 2016 1:41pm
