Home > Technical (L322) > Central locking module
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Hi all,
I'm looking for the central locking module in the car..
Does someone know where is it ?
Thanks in advance
Post #40677 3rd Dec 2010 2:55pm
dan_uk_1984
Re: Central locking module
Fr_Raf wrote:
Hi all,
Thanks in advance
You mean the BCM?
Post #40700 3rd Dec 2010 4:21pm
Fr_Raf
Sorry, my english is not very good.
I mean the receptor in the car for locking unlocking the car whit the key.
What does BCM mean ?
Post #40702 3rd Dec 2010 4:26pm
dan_uk_1984
The Body Control Module or BC Unit controlls all aspects of the cars security and windows etc. The RF Reciever is in the boot and then sends the signal to that. There is a lot of info on the workshop manual on the subject, but here is the summary for the RF Reciever:
RF Receiver
The RF receiver converts the signals from the RF remote handset into digital messages and transmits them to the BCU. The RF receiver is integrated into the rear window antenna amplifier installed behind the inner trim on the top left edge of the upper tail door. Operation of the receiver is powered by a permanent battery feed from the rear fusebox.
Post #40710 3rd Dec 2010 4:57pm
Fr_Raf
Thank you Dan Bow down
I asked that because I had project to change my horrible key to another one. I'll move the transponder from the LR key into the new keyfob. But with your answer, I'm not sure I would be able to connect the new module... Confused
The button of my old key are in very bad condition... and I realy don't want to pay about 270 euros for a new one...
Post #40715 3rd Dec 2010 5:12pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Can you not buy a key from ebay and swap the electronics? 2004 black Vogue TD6
Post #40717 3rd Dec 2010 5:33pm
dan_uk_1984
Agreed, you should be able to swap the entire insides of your key for any replacement. Or just pay the £75 for one from a stealer.
Post #40731 3rd Dec 2010 6:30pm
Fr_Raf
You are right, I can buy a new one, and move all electronics and transponder from mine to the new, but I wondering if I could use one those we can find on the web like this models :
http://www.alarm-discount.com/default/ferm...e-cle.html
http://www.alarm-discount.com/default/acce...cedes.html
Sorry, these links are french...
Post #40747 3rd Dec 2010 7:46pm
RSWilson
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
XUO000020 or XUO500040
Hi All,
Rather than start a new thread I thought I'd follow this one as it is related.
My Remote locking is intermittent at best.
I've tried swapping the battery in the key and re-syncing but it struggles to sync/work and I don't think it is the key as the little red LED on the key flashes fine.
I only have the one key (for now) so I think it is the receiver.
I have uploaded a couple of photo's to show the item and where it is located on a 2004 L322.
All you have to do is pull the top plastic panel off, it is held with plastic clips that stick into metal clips. You need to pull the panel off squarely (not at an angel).
My question is - I've noticed there seems to be an updated part number of XUO500040 in place of the XUO000020 item which is fitted to my car. Am I best fitting the new part? Has anyone else tried this swap for the new part? Are the connectors the same? Am I even correct in thinking it is a newer part number?
Any experience of swapping one of these greatly appreciated.
Thanks
Richard
Post #381507 9th Apr 2016 8:38pm
RSWilson
Hi Folks.
Just to follow up, bought a new receiver off ebay, fitted it and sync'd the key straight away. It works a treat now. I took the old unit apart and found this. It looked fine from the outside too.
Post #382316 15th Apr 2016 8:19pm
PIMCO
Norway
I probably have the same problem. Did you opt for "updated" part number or figure out if there is a difference?
Post #497405 3rd Dec 2018 12:28pm
RSWilson
I think I just bought like for like as that was the cheapest one on Ebay at the time. It worked perfectly and I have never had a problem since.
Post #497420 3rd Dec 2018 2:21pm
mojosung_L32202MYTD6
United Kingdom 2002 Range Rover Autobiography Td6 Adriatic Blue
Hi Richard, i have same problem but i dismentalled the part xuo000020, it looks clean and no water damage. Did you re-program your key by using the diy method , ie. ignition within 5 secs, then held unlock button and pressed lock button three times? i tried this and didnt work.. there is no xuo000020 on ebay for cheap right now so i bought a bmw E53 X5 pn 8377654 which looks the same as xuo000020. however still doesn't work.... P.S. i have sat my car for ten years outside because i was away and now trying to fix it to drive it again. the central locking works but not the remote. so very annoying.
Post #725115 25th Sep 2025 10:41pm
dingg1
Try changing the battery in the key fob
Post #725118 25th Sep 2025 11:14pm
D3Explorer
Hi folks
I picked up a 2007 Vogue and neither of the key remotes work or re-sync, figured it could be the key so bought another and it also fails to resync but my little key rob rf tester is picking up good or strong signal from the key before I press the button.
I expect I need to replace the XUO500040 module, but I noted it has links to the rear window glass and an antenna off under the headlining. Does anybody know if the key receiver is the rear window aerial or up in the shark fin? I also have no GPS signal on the nav so I’m wondering if I should be looking at the aerial in the roof before I splash £150 on a new module!
Annoyingly, the car was unlocking on the key before I had the faulty steering column replaced and now the alarm goes off every time I unlock the car so my remote locking issue has now shot to the top of the repair list!
Cheers
Graeme
Post #725321 29th Sep 2025 11:34am
