Home > Technical (L322) > Headlight bulbs and ballasts
supershuttle
I've got a MY 2010 with bi- zenons and for some time I have thought that the lights weren't as powerful as they used to be, now I know why the OS bulb appears to have failed, I'll do some checks later (swap left and right) to identify bulb or ballast. I've done a quick search but need to be certain before order up some parts, sources and numbers anyone help? Geoff
Post #383019 21st Apr 2016 6:39am
Not come across any issues with 09> headlamps yet Geoff! You must be the unlucky one Whistle
Beware... Yours either take D2R or D3R and both look identical! BUT the wrong one will NOT work in your light pal Thumbs Up
Post #383036 21st Apr 2016 8:47am
Lost for Words
Confused
Bit confused - D2x and D3x bulbs are clearly identifiable because the D3x has a built in ignitor?
Also, don't they take xxS bulbs, being projector systems? Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #383039 21st Apr 2016 9:18am
are they not D3S type?
Post #383041 21st Apr 2016 9:26am
Lost for Words
That's what I'd assumed. Are you thinking of D3S vs D3R, Craig? In which case, it should be the 3200lm D3S because it's a projector system. Visiting from DISCO3.CO.UK
Post #383043 21st Apr 2016 9:36am
supershuttle
So now I am more confused than when I started, also there is no fault showing on the dash but maybe monitoring is switched off. What I'll do is take a bulb out and have a good look for any markings. Geoff
Post #383045 21st Apr 2016 10:01am
'left to right' swap would be the best bet Geoff...also when you get the bulb out you should be able to confirm what type it is.. ... - .- -.
Post #383046 21st Apr 2016 10:04am
Letters numbers Whistle You know what i meant Rolling Eyes
Lazy me working from memory!
The point was Geoff, order the correct bulb (if that proves to be duff) as there are several that look the same, but if one number/letter is wrong! They won’t work...
Post #383055 21st Apr 2016 10:57am
supershuttle
So there was a sticker on the bulb which said amongst lots of other things "D3S 35W E4 OA9 DOT" so I guess that means D3S - doh! next is the left right swap. Geoff
Post #383069 21st Apr 2016 12:19pm
supershuttle
and its the bulb - cheapest? Geoff
Post #383093 21st Apr 2016 2:51pm
supershuttle
Ordered from xenons4u 40quid for two, could have nipped round to Halfords and paid 140 quid for one Very Happy Geoff
Post #383096 21st Apr 2016 3:10pm
did you take this opportunety to get 6000k bulbs or did you stick to the OE 4300k ? ... - .- -.
Post #383097 21st Apr 2016 3:26pm
supershuttle
Sticking with OE, then I will have a spare. Geoff
Post #383103 21st Apr 2016 4:35pm
Thumbs Up ... - .- -.
Post #383109 21st Apr 2016 5:32pm
supershuttle
Bulbs arrived both fitted, both working. It's worth noting that although they are very easy to change it pays to be gentle Very Happy Geoff
Post #383681 25th Apr 2016 1:31pm
