![]() | Home > Technical (L322) > Headlight bulbs and ballasts |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3963
I've got a MY 2010 with bi- zenons and for some time I have thought that the lights weren't as powerful as they used to be, now I know why the OS bulb appears to have failed, I'll do some checks later (swap left and right) to identify bulb or ballast. I've done a quick search but need to be certain before order up some parts, sources and numbers anyone help? Geoff |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
are they not D3S type?
That's what I'd assumed. Are you thinking of D3S vs D3R, Craig? In which case, it should be the 3200lm D3S because it's a projector system. Visiting from DISCO3.CO.UK
So now I am more confused than when I started, also there is no fault showing on the dash but maybe monitoring is switched off. What I'll do is take a bulb out and have a good look for any markings. Geoff |
'left to right' swap would be the best bet Geoff...also when you get the bulb out you should be able to confirm what type it is.. ... - .- -.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Letters numbers |
So there was a sticker on the bulb which said amongst lots of other things "D3S 35W E4 OA9 DOT" so I guess that means D3S - doh! next is the left right swap. Geoff |
and its the bulb - cheapest? Geoff |
Ordered from xenons4u 40quid for two, could have nipped round to Halfords and paid 140 quid for one |
did you take this opportunety to get 6000k bulbs or did you stick to the OE 4300k ? ... - .- -.
Sticking with OE, then I will have a spare. Geoff |
Bulbs arrived both fitted, both working. It's worth noting that although they are very easy to change it pays to be gentle |
