![]() | Home > Technical (L322) > Engine Oil Question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
its a tad warmer where you are so i would use an oil that works well in the heat.... ... - .- -.
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Thanks and yes but the advice is conflicting!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
The recomended oil for African use is still 5w 30 sir... I would not advise deviating from that! |
Thanks for that but its not available here.
a quick google comes up with 10w40... ... - .- -.
The spec to look for is FORD WSS-M2C-913-C. This is what LR specify for the TDV8. Find something which meets that and it will be fine. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Are you doing oil changes every 5000km Jerry, or doing a oil change in between a service? ______________________________
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
What Dom said, but the spec ends with a B not a C
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
It's actually now up in D now! Regarding the Ford engine oil specification of TDV8 3.6 the Ford WSS M2C913-D is the latest specification, which superseded the previous Ford WSS M2C913-C, Ford WSS-M2C913-B, Ford WSS-M2C912-A and 913-A.
Thanks for the input guys, its much appreciated. I have no idea what WSS M2C913-D means (well I do now as I've just googled it) but it occurred to me I'll try the local Merc dealer here who are also the Jeep agent and have quite a few on the road. The LR dealer lost the dealership here a couple of years ago (but I would NEVER use them!). Pete: Yes its a done thing here to service every 5000klms. Heat/dust/road conditions and rubbish fuel mean it has to be done. Diesel here is well over 1000ppm, compare to Australia/Europe/UK which is 5-10ppm. Cheers, Jerry THIS WRECKAGE |
Fair enough. I'm considering doing at least a rear sump plug drain in between main services. I'll probably end up doing both. ______________________________
Hi Pete,
Check out the two sump plugs and locations here: http://www.fullfatrr.com/forum/topic28510-53.html Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
Thanks Edfors, great pics.
