Home > Maintenance & Mods (L322) > flip key - car wont start
Page 1 of 3 123>
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
hi all, well i done the flip key upgrade, wish i hadnt bothered.
transfered the old transponder into the new flip casing, put it behind the rechargeable battery?
went out to the car and turned ignition to position 1
coded key to car, got confirmation locks, but the central locking buttons on the key still didnt work. my old key buttons have now stopped working
worst of all, it wont start the car, it turns all the way ignition comes on etc but no turn over
have i done something wrong, does it matter where the transponder chip is in the car? any ideas?
Post #383711 25th Apr 2016 3:41pm
Well on mine the transponder has to be right down the front of the key by the key blade, when programming you have to do ALL keys including the old ones or it locks them out... Pete
Post #383716 25th Apr 2016 3:57pm
Ohwhatalad
I have looked at IID it says
95 - interior security fuse or cable
i have checked all immobiliser fuses in the glovebox but all seem good.
it locks and opens door by the key hole and also turns the electrics on fine to ignition stage, just wont turn the car over
any thought?
old key doesnt matter it has no transponder anymore, just mentioned it as ive obviously programmed it out of the system and the new one still isnt working
Post #383720 25th Apr 2016 4:10pm
Ohwhatalad
think battery is a bit flat, need to order a new one think its still on its original Land rover battery Embarassed
will report back after a charge
Post #383725 25th Apr 2016 4:40pm
FYI you have two totally separate things with the key, you programme it to lock/unlock the car only, this has nothing to do with starting, the transponder has to talk to the car to enable starting with the correctly cut key, so your issue can only be with the transponder if the key turns and nothing happens...
Or, as you say, a flat battery.... Thumbs Up Pete
Post #383746 25th Apr 2016 6:11pm
Ohwhatalad
hi pete yep, understand that. not sure why the procedure locked my doors for me then still didnt work!
anyway i have moved the chip to the top of the key nearer the flip blade and the battery is on charge, so we shall see!
i think the battery is the original that came with the car over 10 years ago lol. well its original LR at least. need to order a bosch
Post #383760 25th Apr 2016 6:56pm
Ohwhatalad
OK so the car starts, must of been the battery,
the remote will not sync to the cars central locking though,
I insert the key, turn to ignition 1
Remove the key (within 5 seconds)
Hold unlock and press lock 3 times, it does nothing, but if i press lock 4 times, the car locks and unlocks.
i then put the key back in ignition and quickly go to 1 and off again. key does nothing.
where am i going wrong here ive done it 4-5 times?
Post #383772 25th Apr 2016 7:42pm
daveo
hi
why did you not contact me... as mentioned the chip has to be right at the front of the key you will find there may be a blank chip there remove and replace, listen for the click as your key goes in..
WORD OF WARNING IF YOU START YOUR CAR DO NOT REMOVE THE CHIP OUT OF THE IGNITION RANGE AND THATS ONLY ABOUT 50MM AS WHEN YOU STOP THE CAR IT WILL TRY TO RIGHT BACK THE ROLLING CODE TO THE CHIP AND IF ITS OUT OF RANGE YOU WILL LOCK YOUR EWS UNIT..
PM me your number if you need help
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #383776 25th Apr 2016 8:27pm
Ohwhatalad
hi davao, all is fixed with the starting, it starts fine now Smile
I just can't get the central locking to sync, I'm following procedure and get the lock/unlock from the car but it still doesn't work?
do these new remotes need charging from a drive before working properly or something? cheers
Post #383777 25th Apr 2016 8:34pm
daveo
you are doing something wrong, how many keys are you trying to sync V8 facelift Range Rover Autobiography 22" wheels.
Post #383783 25th Apr 2016 8:49pm
Ohwhatalad
just this new one, i did try my old key just to test it and its knocked that one off so I've obviously done something
like i say it locks and unlocks the car when I'm doing it but after that the key does not work I'm baffled read instructions and done it step by step several times i can't understand what I'm doing wrong
Post #383785 25th Apr 2016 8:54pm
Ohwhatalad
Noticed that when i do the procedure all doors lock but only the drivers side unlocks again all the others remain locked
not sure if thats normal.
just been out tried it again several times, always get the lock as if its complete but no buttons work afterwards Sad
Post #383787 25th Apr 2016 9:10pm
daveo
when you finish the sync and the doors lock then un lock do you put the key back into the ignition and turn the ignition on then off V8 facelift Range Rover Autobiography 22" wheels.
Post #383789 25th Apr 2016 9:30pm
Ohwhatalad
the doors all lock and the only door to unlock is the drivers
i then put the key in and turn to ignition 1 and off again
should i be turning to full ignition on, stage 2 at the end? or 1 like in the beginning.
Post #383790 25th Apr 2016 9:31pm
daveo
i put the key in and start the car, are all the doors closed when you sync V8 facelift Range Rover Autobiography 22" wheels.
Post #383803 25th Apr 2016 11:03pm
Page 1 of 3 123>
