![]() | Home > Maintenance & Mods (L322) > flip key - car wont start |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Will it totally unlock the car if the stupid anti hijack system is working? Only one press of my open button only opens the drivers door.... I have to press it twice to open the whole car |
That might be the problem... if the voltage is down maybe it's not re-writing the key code in the ECU....
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
Hmmm maybe, not sure the BCM would send signal to doors to lock unlock if that was the case though, anyway i have ordered a new battery coming tomorrow so that will confirm whether or not the battery is at fault here.
Ohwhatalad.. I'm afraid that I haven't done this mod, so I'm not too sure how much help I would be |
Full charged my battery today.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
They say to leave the engine running because a dodgy battery will go flat in minutes with the door open...
Got that fault permanently on mine and I've swapped to a flip key, infact I'm on my second one... Knowing how fickle FF's are it might be the issue, but might not.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Its so weird that it locks and unlocks the drivers door when i press the sequence in programming, but then will not work afterwards!! could it be a dodgy key chip or something? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Sorry if this is totally wrong but are you doing just one key or moving on to do a second? John
Try programming the original remote back in, you don't need to replace the transponder, start the sequence with the new key, then try to programme the old one... |
Just the one new key
Same question are you synching two keys or one whether new or old? John
One key |
