![]() | Home > Maintenance & Mods (L322) > flip key - car wont start |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Well on mine the transponder has to be right down the front of the key by the key blade, when programming you have to do ALL keys including the old ones or it locks them out... Pete
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
I have looked at IID it says
think battery is a bit flat, need to order a new one think its still on its original Land rover battery |
FYI you have two totally separate things with the key, you programme it to lock/unlock the car only, this has nothing to do with starting, the transponder has to talk to the car to enable starting with the correctly cut key, so your issue can only be with the transponder if the key turns and nothing happens...
hi pete yep, understand that. not sure why the procedure locked my doors for me then still didnt work!
OK so the car starts, must of been the battery,
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi
hi davao, all is fixed with the starting, it starts fine now |
you are doing something wrong, how many keys are you trying to sync V8 facelift Range Rover Autobiography 22" wheels.
just this new one, i did try my old key just to test it and its knocked that one off so I've obviously done something
Noticed that when i do the procedure all doors lock but only the drivers side unlocks again all the others remain locked
when you finish the sync and the doors lock then un lock do you put the key back into the ignition and turn the ignition on then off V8 facelift Range Rover Autobiography 22" wheels.
the doors all lock and the only door to unlock is the drivers
i put the key in and start the car, are all the doors closed when you sync V8 facelift Range Rover Autobiography 22" wheels.
