Home > Technical (L322) > Wipers a bit erratic...
mjdronfield
So, yesterday, left work with the auto wipers on, it was raining, they worked, but occasionally parked diagonally across the screen...
Resolved by moving the stalk to somewhere else, then they parked correctly.
Then noticed that the single wipe you get by pushing the stalk down was more like 4 wipes.....
Done the same tonight.....
Anyone else had this ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #384352 28th Apr 2016 7:35pm
exalin
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I had something similar towards the end of last year although in addition to the erratic behaviour, the wipers stopped working completely after a while until I turned the engine off and on. Not ideal in the rain!
Took it back to the dealer and they diagnosed a faulty wiper motor which was replaced under warranty. However, could also be a wiper relay problem - http://www.fullfatrr.com/forum/topic27902....iper+relay
Post #384358 28th Apr 2016 8:03pm
I had the same problem, then remembered I'd left my spare sarnies under the bonnet and they had got in the way of the wiper motor.... Most people won't understand this but you know what I mean Mark.... Whistle Whistle Rolling with laughter Rolling with laughter Pete
Post #384363 28th Apr 2016 8:40pm
mjdronfield
You need to be careful where you store your emergency backup sarnies !
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #384371 28th Apr 2016 9:13pm
mjdronfield
So.... How would a dodgy wiper motor make it do 4 or 5 wipes instead of just the single one when you press the stalk down? Some type or short for the same time?
I can see it making the wipers park in the wrong position..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #387234 15th May 2016 4:40pm
It's got a circular section with different sized tracks around it to let the motor know where in the arc the wipers are, I would imagine if this was worn or damaged then it could miss reading where it was and carry on for several more wipes before it found itself again....
This kind of thing...
 Pete
Post #387237 15th May 2016 5:16pm
scotbruce
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Similar, initial behaviour last year, which quickly worsened - likewise, new wiper motor Sad
Post #387252 15th May 2016 8:38pm
mjdronfield
New wiper motor purchased from Land Rover at a discounted price of £207 inc VAT.
Then off to my local independent to fit. He bent 2 pullers trying to get the wiper arms off the spindles, as the new motor comes with linkage and spindles etc.
Gave up in the end, and fitted new motor to old linkage..... £72...,,
Will see how we go !
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #388493 24th May 2016 3:41pm
mjdronfield
So.... I'm guessing the little micro switch is the cause here, as they have been fine since the motor swap.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #389100 28th May 2016 4:16pm
