Home > Wheels & Tyres > Slack nuts !
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Slack nuts !
After painting my calipers and refitting my wheels I've now noticed when tightened up ( Embarassed havent got a torque wrench ), there is 'slight play' on the nut and seems to move left/right about 1-2mm
I've taken one wheel off and re aligned everything but still the same
Any ideas?
Post #384593 30th Apr 2016 12:20pm
Which Nut? Caliber or wheel? There is nothing that can't be fixed with a hammer😜😜
Post #384594 30th Apr 2016 12:24pm
J evro
Wheel nuts Very Happy
Post #384595 30th Apr 2016 12:25pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
It's either:
1) Not tightened up enough.
2) Stud is spinning so not letting you tighten it up enough.
3) Thread is damaged so it's feeling tight before it actually is.
1) is easy to fix.
2) and 3) you need to take the wheel off and inspect the studs.
It's important that the back of the wheel where it mates the hub and the hub itself are cleaned up, including the hub-centric flange (the middle bit) so the wheel sits flat and true. A thin smear of copper grease on the mating surface to prevent dis-similar metal corrosion is advisable, lets you take the wheels off easier at a later date!
Post #384597 30th Apr 2016 12:34pm
What sized socket are you using?
is it possible that your nuts have swollen and you have used the size up and what you are feeling is the cap moving? The nut itself corrodes under the cap and loosens it off and means that you can't get the 22mm on and have to use a larger than needed socket, get new nuts. is the easiest solution. There is nothing that can't be fixed with a hammer😜😜
Post #384599 30th Apr 2016 12:39pm
The nuts have a stainless cover that fits over the actual nut, you put the socket over these covers, they will have play in them and move a bit, as long as the nuts are done up tight you will be OK.... Thumbs Up Pete
Post #384605 30th Apr 2016 2:05pm
pld118
Was going to say what Haylands said also Thumbs Up
Post #384607 30th Apr 2016 2:10pm
Haylands is your man , sloppy stainless steel caps . think nothing of it Thumbs Up 2008 MY Supercharged
Post #384624 30th Apr 2016 5:49pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I agree! Thumbs Up
Post #384641 30th Apr 2016 9:00pm
J evro
Well done those that said.......Loose SS Caps you were all quite correct Thumbs Up
Just wish I had read the posts before taking the wheels back off and sanding off all the mating surfaces Big Cry
Post #384710 1st May 2016 10:18am
Hope you put some grease on those mating surfaces otherwise you will have corroded on wheels the next time you try to take them off.... Thumbs Up Pete
Post #384737 1st May 2016 12:45pm
J evro
All greased up matey Thumbs Up
Post #384744 1st May 2016 1:12pm
