![]() | Home > Wheels & Tyres > Slack nuts ! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Which Nut? Caliber or wheel? There is nothing that can't be fixed with a hammer😜😜
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Wheel nuts |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
It's either:
What sized socket are you using?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8572 ![]() ![]() ![]() |
The nuts have a stainless cover that fits over the actual nut, you put the socket over these covers, they will have play in them and move a bit, as long as the nuts are done up tight you will be OK.... |
Was going to say what Haylands said also |
Haylands is your man , sloppy stainless steel caps . think nothing of it |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 341 ![]() ![]() ![]() |
I agree! |
Well done those that said.......Loose SS Caps you were all quite correct |
Hope you put some grease on those mating surfaces otherwise you will have corroded on wheels the next time you try to take them off.... |
All greased up matey |
