![]() | Home > Technical (L322) > TDV8 engine noise |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
Hi guys, I have noticed recently my engine seems to be noisier than usual when idling. It's driving fine and there are no warning lights but it sounds odd on tick over. I have nothing to compare against so have put a video on the tube and would be grateful if you could have a listen and give me your opinion. It was also serviced and MOT'd just a few weeks ago.
No, same fuel as usual which is normally supermarket.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
is that not the a/c compressor switching on and off?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Not got anything to compare it to, but could it not be an ancillary such as a water pump or alternator bearing? Rather than the engine itself?
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
^ At last, someone else who has heard of this trick. Last time I suggested this (on another forum) I was ridiculed soundly. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
the sound switching in and out is likely to be the AC compressor as said. it will engage and disengage as needed. turn the AC off and it should stop. |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Whilst I've not seen it done with a screwdriver Paul Bass (owner of Challenger 4x4 did this on mine to confirm a dodgy alternator), he had a specially made device (metal rod and funnel!) Ed |
Thanks guys, I'll have another play. I am familiar with the screwdriver trick, I've used it many times myself.
It is the air on switching on and off but even with it off I am now paranoid that it is too noisy. I've had the screwdriver on what parts I can actually get to and they all sound noisy 😣
Have you checked things like oil level after the service?
Is that what it sounds like warm or just after start up?
Thanks guys.
Well it turns out the noise was the air con compressor. I got this replaced and it's much better now although the first time I took it,for a decent drive, going on holiday, the fan belt broke. I'll be having a word with the garage when I get back tomorrow.
