![]() | Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Most JLR agents use the Vacuum method sir... In fact, if you have a 4.4 then thats the only approved way to change the engine oil...
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Ok, thanks for that.
I did my last 3.6 using the vacuum method, then removed both plugs and got a very small amount out! Same with the 4.4 TDV8 i own now and again got a dribble out of both!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8610 ![]() ![]() ![]() |
There will always be some left, the pipe won't sit on the bottom and suck the lot out, but I bet there is more oil stuck in nooks and crannies in the rest of the engine than left in the sump... really can't see any link with that small amount of old oil and turbo failure... Pete
OK, thanks again, all sounds logical.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Does the sdV8 have two sump plugs? |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1666 ![]() ![]() ![]() |
The 4.4tdv8 sump plugs x 2 are (apparently) fragile and not designed to be removed often. Don't know about the SDV8. The pumped method came in due to health and safety and hazardous materials handling regulations so one would assume the method is capable of doing the job properly. I note Craig only has a dribble out of the sump plug so it seems like the pump method does the trick. |
Fragile?????
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Does the 4.4 actually have sump plugs? I thought it just had a push on connector for the scavenger pipe? There is nothing that can't be fixed with a hammer😜😜
It does have a sump bang but it's under the subframe meaning you could not drain the sump as there would be oil jettisoned everywhere!!! |
Welcome to the new age of servicing sir! Mercedes have had the same system for years! ![]() |
top forethought and planning there...... is it by any chance blocked by the subframe on the 405 too? Didn't think there was a sump drain option :thumbs: There is nothing that can't be fixed with a hammer😜😜
The 405 does not have a dipstick? So where do you put the vacuum pipe to suck it out? |
