![]() | Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Where is that ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Not being sarcastic here... The tube is where you would expect to find the dipstick sir... Left side front (ish) similar place to the 3,6 |
Arrrrr wondered what that was?
What is the best and most suitable vacuum to use ? There are loads on eBay? |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
I use one called mityvac, although it's not quite large enough for to remove all the oil in one go
Just checked and the id of the tube is only 5.4mm so a 5mm tube needs to go down there. Thats not much of an id to get the oil oil out, especially if its cold! It must take ages! |
The mityvac comes with different tube diameters that will fit down most (if not all) dipstick pipes
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
a tube doesn't go down the dipstick tube it attaches to the top of it, on the 4.4 the tube is connected to a drain off point at the bottom of the sump |
REALLY??
That's what I was told.... Could have been bamboozled though. Mine has a kinda of bayonet fitting on the top. There is nothing that can't be fixed with a hammer😜😜
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Two questions if I may...
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 356 ![]() ![]() ![]() |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
I have one very similar to that but only sucks the oil out.
Thanks A380 - nice one |
