Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum
Page 2 of 3 <123>
There is a tube on the in the engine bay with a little black cap on it. Push and twist to remove then plug in the vac. There is nothing that can't be fixed with a hammer😜😜
Post #385388 5th May 2016 4:51pm
wealy
Where is that ?
It's not in the service manual ?
Any pictures would-be helpful?
Post #385455 5th May 2016 10:08pm
Not being sarcastic here... The tube is where you would expect to find the dipstick sir... Left side front (ish) similar place to the 3,6 Thumbs Up
Post #385462 5th May 2016 10:30pm
wealy
Arrrrr wondered what that was?
Cheers
Post #385495 6th May 2016 7:53am
wealy
What is the best and most suitable vacuum to use ? There are loads on eBay?
Post #385496 6th May 2016 7:54am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I use one called mityvac, although it's not quite large enough for to remove all the oil in one go
Works very well
Post #385515 6th May 2016 10:58am
wealy
Just checked and the id of the tube is only 5.4mm so a 5mm tube needs to go down there. Thats not much of an id to get the oil oil out, especially if its cold! It must take ages!
Post #385529 6th May 2016 12:28pm
cheezels
The mityvac comes with different tube diameters that will fit down most (if not all) dipstick pipes
With warm engine, sucking the oil out of my last car took about 20 mins max
Post #385535 6th May 2016 12:54pm
a tube doesn't go down the dipstick tube it attaches to the top of it, on the 4.4 the tube is connected to a drain off point at the bottom of the sump Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #385568 6th May 2016 4:16pm
wealy
REALLY??
This is the 4.4 SDV8
Post #385570 6th May 2016 4:37pm
That's what I was told.... Could have been bamboozled though. Mine has a kinda of bayonet fitting on the top. There is nothing that can't be fixed with a hammer😜😜
Post #385617 6th May 2016 8:10pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Two questions if I may...
1. Does anyone know where the vacuum suction hose fits to extract engine on a 4.4TDV8? Is it where the oil filter is located in the vee or some other place? and
2. Approximately how much new oil would be needed for such a change?
The 4.4tdv8 wiki method shows draining from the bottom which I don't want to do with fragile awkward to get to sump plugs.
Thanks Gents Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #385623 6th May 2016 8:45pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi ajac8
see my post: ENGINE OIL RENEW & TRANSFER BOX OIL
This is the unit we use - its a 18L pump oil extractor- you can suck oil out or pressure it in - very very good - I think it cost us £580 but having said that worth every penny - does the job - dont buy a cheap unit - same as a ford !!!!!
All you have to do is connect to the oil tube ( see my post above ) - pressure the pump up by only 3 or 4 pumps - walk away have a cuppa T then come back and 9.5L is out - I've taken the sump off before to see how much was left and nothing - that's how good it is.
Remember what comes out goes back in - I have made a measure scale on the side - so I know every 1 litres what the level is. - when you buy the unit fill it with brand new oil up to 9 litres and mark the side - then add another 0.5 litres and again mark the side - then add another 0.5 litres to show 10 litres.
The 4.4TDV8 will hold 9.5 litres with a oil filter change - however I always run the oil at 9.2litres this takes into account summer weather when the oil and engine get hot it will not be over stressed/ full in the engine which is a no no - so many fill their cars to the max on the dip stick and in hot weather oil is under a lot of pressure
( the FFRR has a high pressure oil pump - that says it all )
bare in mind the electronic oil level gauge is not 100% accurate - you will notice it sometimes jumps a increment !!!
remember to put the Oil Drain black cap on after - ensure its pushed down and turned to lock - good luck ajac8
One last thing - its that easy to do - I do our cars every 7,000 miles - peace of mind
Hope this helps you
Post #385634 6th May 2016 9:45pm
proser
I have one very similar to that but only sucks the oil out.
Every other oil change I will vacuum out about 6 litres and then drain the rest from the sump plugs, just to check that there is nothing in the oil that shouldn't be.
I tend to do both mine and the wife's car at the same time, they both use the same spec oil. Once I have extracted all the oil I then use the empty containers to pour the old oil into to them take to the recycling centre to dispose of.
On the RR, whilst the oil is being extracted I tend to replace the oil filter, then check/replace air & pollen filter and top up washer bottle. By the time I have done all that the oil has been removed and then straight onto putting fresh back in. All completed in about 30mins and without having to put overalls on. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #385643 6th May 2016 10:51pm
ajac8
Thanks A380 - nice one Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #385804 7th May 2016 6:05pm
Page 2 of 3 <123>
