|  | Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | Where is that ?
|  5th May 2016 9:08pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Not being sarcastic here... The tube is where you would expect to find the dipstick sir... Left side front (ish) similar place to the 3,6  | ||
|  5th May 2016 9:30pm |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | Arrrrr wondered what that was?
|  6th May 2016 6:53am |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | What is the best and most suitable vacuum to use ? There are loads on eBay? | ||
|  6th May 2016 6:54am |
| cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279      | I use one called mityvac, although it's not quite large enough for to remove all the oil in one go
|  6th May 2016 9:58am |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | Just checked and the id of the tube is only 5.4mm so a 5mm tube needs to go down there. Thats not much of an id to get the oil oil out, especially if its cold! It must take ages! | ||
|  6th May 2016 11:28am |
| cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279      | The mityvac comes with different tube diameters that will fit down most (if not all) dipstick pipes
|  6th May 2016 11:54am |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | a tube doesn't go down the dipstick tube it attaches to the top of it, on the 4.4 the tube is connected to a drain off point at the bottom of the sump  | ||
|  6th May 2016 3:16pm |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | REALLY??
|  6th May 2016 3:37pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | That's what I was told.... Could have been bamboozled though. Mine has a kinda of bayonet fitting on the top. There is nothing that can't be fixed with a hammer😜😜
|  6th May 2016 7:10pm |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672      | Two questions if I may...
|  6th May 2016 7:45pm |
| EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361      | .
|  6th May 2016 8:45pm |
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452      | I have one very similar to that but only sucks the oil out.
|  6th May 2016 9:51pm |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672      | Thanks A380 - nice one  | ||
|  7th May 2016 5:05pm |
| Posting Rules
