![]() | Home > Technical (L405) > Battery location? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Anyone know where the battery is on a 405?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8020 ![]() ![]() ![]() |
The main one is under the spare wheel
Thanks Alistair. Which one should you plug the ctek onto I wonder? Would it matter? |
Whilst cleaning the car at the weekend I decided to have a look for the batteries. I found the one behind the panel on the right hand side of the boot area. I took the spare out to give it a a clean and it is not under the wheel? The compressor is there and there is no room for a battery?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35692 ![]() ![]() |
it should be there,
Thanks Stan.
if you have starting problems then maybe someone has nicked it |
They would not nbe able to find it! |
Here you go - and yes I know my wheel well could do with a vacuum, but I did empty it & remove the spare wheel just to take the photos....
Thanks Alistair, there is carpet covering all that on mine. When I get round to it I will have a closer look now I know its there somewhere!
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 913 ![]() ![]() ![]() |
Reviving this old post as I'm planning to replace my all leather steering wheel currently fitted with a new piano black / leather wheel at the weekend. As I'll need to disconnect & remove the steering wheel airbag, assuming I'll need to disconnect BOTH batteries to avoid SRS errors? |
