Home > Off Topic > Led resistor fix ?
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Led resistor fix ?
For my Ducati I have an integral led indicator/side and brake light which causes the fast flash. Bought two resistors which each have two wires in two wires out.
Question is anybody know which wire goes where ?
I will get the multi meter out just hoped I was missing something obvious
 Many thanks
Paul
Post #385595 6th May 2016 6:38pm
You wire them across the bulb - in parallel - so one wire to each of the wires that goes to the bulb
Post #385604 6th May 2016 7:14pm
Pvw10
But resistors have four wires each, in picture there are five wires total and they cover side/brake/earth/ winker x 2 I guess hence brain fade Many thanks
Paul
Post #385605 6th May 2016 7:19pm
2 in 2 out sounds like a pair together - but hard to tell.
Normally you'd have 25-50 ohms across the bulb - or from the live supply to earth which is effectively the same thing.
On the 5 wire one, it would sound like they have wired 4 together inside 1 box, with a common earth already.
4 wires is hard to tell - could be 3 resistors with a common 1 earth - or 2 resistors with 2 wires each.....
Time to get the meter out
Post #385609 6th May 2016 7:30pm
Pvw10
Your right matey, cunning these Chinese.
Many thanks for your thoughts 👍 Many thanks
Paul
Post #385610 6th May 2016 7:32pm
