![]() | Home > Maintenance & Mods (L322) > [SOLVED] No Screen (non touch), No radio, No indicators |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Not had a chance to dive in to the fuses yet, but thought I would put this out there.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35736 ![]() ![]() |
weird one Tim...could it be a slipping alternator belt and low battery thus not giving all the ecu's the power they need. ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8678 ![]() ![]() ![]() |
Sorry to say that's what happened to mine when I parked it in that river.... radio died just like yours and the indicators did the same thing... and that was definitely water somewhere.... |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Same happened to mine, it was water ingress in the rear |
Battery at a reasonable 12.7V, engine running 14+V .
Yes Pete, given it is dry at the rear, does point to LCM/BECM. Methinks the LCM most likely culprit....
Still weird it's the radio as well....
isnt there an ecu in the passenger footwell that can get wet? ... - .- -.
Yeah, the headlight leveling... funnily enough Craig noticed mine worked when I started fatty and recons it's only about the third one he's ever seen that still works, he says most weren't even fitted with the ECU.... |
Mine works too (or was working!) |
"Pick me! Pick me!" shouted the Range Rover as I stepped out of the front door this morning. "No", I replied sternly, "You let me down yesterday and stopped working properly, I can't trust you in case you get worse. Anyway it is going to be a nice day, so I'm taking the Audi." The Range Rover frowned and shrunk back into its parking space on the drive.
i like nice ending stories. |
Tim, wish ours had, SWMBO was down in Kent at the weekend and the Mechatronic unit for the DSG in her TT thinks it's a Range Rover and spat it's dummy out... Green Flag have taken 4 days to get it home (complaint in progress) and I'll be delving into it's gearbox tomorrow, apparently you can just get enough room to get the unit out the box and leave most of it in the car.... we'll see.... ![]() ![]() Glad yours has fixed itself... ![]() I use this stuff for waterproofing the Rangie's electrics... it's not cheap but seems to work very well, have a good nose round and squirt lots of bits.... ![]() ![]() http://www.corrosionx.com/corrosionx.html Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
UPDATE
That does seem very weird Tim, maybe just moist air getting into one of the plugs...
