Home > Technical (L322) > Is this good advice?
bebechoon
France
Hi, all!
I know there are automatic gearbox experts (and many other wise heads!) on this forum, and I would like to ask for their valued opinion. Question
This link: https://www.youtube.com/watch?v=6zzEtxJkC7Y presents 5 things you should never do in a car with automatic transmission. One of the 5 arguments put forward (starts at 7min15) is that “there is no reason to put your car in neutral when sitting at a stop light … it’s fine to leave it in drive”.
I have always religiously put mine into neutral (or even Park) when stopped for more than a couple of seconds in the (apparently) mistaken belief I was doing the gearbox good by relieving the strain on it. ‘Not so’ says this young man …
I also thought there could be a safety issue – what if your foot slips off the brake?
What is the forum’s collective wisdom on this, please? Does it really matter one way or the other? Bow down
Thanks! It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #387509 17th May 2016 3:13pm
Weegie
I put mine in neutral when stopped at traffic lights etc, Steve. The reason being that the Td6 has a resonance when stopped in gear which tends to send a low level vibration through the car. It has been mentioned previously on here.
The handbook also says not to keep it in drive when stationary with the engine running for a "prolonged" period. John
GAP iiD BT-Sold
Post #387525 17th May 2016 4:26pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I too always put it in N unless it is obvious I will be stationary for just a few seconds.
Just seems right. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #387529 17th May 2016 4:47pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Me too, neutral when stood in traffic, lights, etc Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #387533 17th May 2016 4:53pm
Clivefog
Over 30 years of driving autos, leave in drive foot brake on and enjoy.
Post #387536 17th May 2016 4:59pm
ajac8
/\ Not saying you're wrong but just doesn't sound right - surly you are placing undue wear on any clutch or such like thus reducing the service life span.
I suppose in retrospect you could also say moving box parts into N does the same to lifespans so the question is what is the correct procedure according to the manufacturer - anyone know? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #387545 17th May 2016 5:20pm
Weegie
I quoted the handbook but "prolonged" isn't defined. On the Disco 2 I leave it in drive but will continue to go into N in the FF unless, as you say, only stopping for a few seconds. John
GAP iiD BT-Sold
Post #387548 17th May 2016 5:29pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Put mine into neutral, when stopped at lights etc.
as above the handbook states to do it. Thumbs Up
I did watch a video on you tube, not sure if it was posted on here, but it concerned the tc. American chap was explaining to a group of students what happens when you wind the tc up on the brake, the temperature increases really rapidly and can overheat the oil in no time.
so I did have a good think, and apart from the above mentioned resonance on the td6, on a smaller scale, the tc is trying to push the car forwardand could create a lot of heat in the oil, so could be one of the reasons it's in the handbook.
greg.
Post #387551 17th May 2016 5:43pm
bebechoon
France
Ah yes, John (Weegie) and gregdav, you’re right. My Owner Manual says: “DO NOT allow the vehicle to remain stationary for any length of time with a drive gear selected and the engine running (always select ‘N’ if the engine is to idle for a prolonged period).
Seems pretty clear to me (apart from the definition of “prolonged”!). I guess I should’ve read the good book before asking Embarassed
Anyway, I’m going back to sticking it into neutral unless it’s only a brief stop, as has (mostly!) been said above. Exclamation It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #387554 17th May 2016 5:56pm
I think the highway code wants you to place the car in N and apply the handbrake on an auto too Whistle
I have to admit, I’m lazy and don’t but i think you probably should Whistle
Post #387556 17th May 2016 6:11pm
Advanced driver training wants you to go to neutral and handbrake on (manual or auto).
Makes sense as not too much can go wrong in this state.
But I am always out of gear and handbrake on if lingering for more than a few seconds .
Post #387617 17th May 2016 11:31pm
Neutral and handbrake every time because i'm lazy and can't be arsed keeping my foot on the brake for a minute and a half Wink newer auto boxes now disengage drive when stationary to save fuel so if the manufacturers do it and Land Rover recommends it it must be " neutral engaged and handbrake on" . And i have NEVER had a problem with my electric handbrake because I use it , all the time Thumbs Up 2008 MY Supercharged
Post #387628 18th May 2016 2:09am
