![]() | Home > Technical (L322) > Temp gauge |
Sounds like you need a new thermostat (or one of the many that there are) would start with the main one though. IIRC, you are lucky and this is an electrical one and sits nicely at the top of the engine at the front on petrol models. .
mk1paul Member Since: 01 Jul 2014 Location: Hampshire Posts: 109 ![]() ![]() ![]() |
Great - I did wonder if that is what was needed.
Have ordered a new thermostat and gasket from Dan at Duckworths.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Just be careful sir, the 4.2 can be a challenge to bleed at the best of times |
Now I am worried.
Ok I am getting the courage to have a go at this.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Isn't it going to be the same as a Jag XJR? Lots of guides for that. |
I didnt think of that!
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Pretty easy if I remember rightly, as you look in the engine bay from the front its kindof to the right of the centre of the engine at the front. Look for a big metal tube connected to rubber water hoses about the same size and shape as the new thermostat you will get. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 614 ![]() ![]() ![]() |
same year as mine easy job took about half hour on mine . Think it was some american bloke i watched doing it step by step online v good will try and find it |
