Home > Technical (L322) > Temp gauge
mk1paul
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
Temp gauge
Hi guys
I need some help please.
I have a 4.2 Supercharged 2005 model.
My temperature gauge is "erratic". When driving round town it will sit nicely on the halfway point. However once I get a run of 50 mph or more, it quickly drops to the quarter line (or below). My air con also seems to be affected by this as I lose cold air when it drops.
Does anybody have any idea what this might be?
Post #387829 19th May 2016 12:05pm
Sounds like you need a new thermostat (or one of the many that there are) would start with the main one though. IIRC, you are lucky and this is an electrical one and sits nicely at the top of the engine at the front on petrol models. .
Post #387873 19th May 2016 3:43pm
mk1paul
Great - I did wonder if that is what was needed.
I have tried to search for a method/video to change it on the 4.2 Supercharged Jag engine but cannot find one.
Will have a look at the Jag forum I guess
Post #387876 19th May 2016 3:44pm
mk1paul
Have ordered a new thermostat and gasket from Dan at Duckworths.
Just need to find out how to change it now!
Post #388123 21st May 2016 8:23am
Just be careful sir, the 4.2 can be a challenge to bleed at the best of times Rolling Eyes
Post #388135 21st May 2016 9:49am
mk1paul
Now I am worried.
Might takes it to my local garage!
Post #388141 21st May 2016 10:11am
mk1paul
Ok I am getting the courage to have a go at this.
Do you guys think this is a DIY job?
Any guides available as I cannot see them online anywhere for the Supercharged 4.2
Slightly concerned that it is a bigger job than expected?
Post #395438 11th Jul 2016 10:25am
mr_spock
Isn't it going to be the same as a Jag XJR? Lots of guides for that.
Post #395440 11th Jul 2016 10:30am
mk1paul
I didnt think of that!
Will google around to see.
Thanks
Post #395443 11th Jul 2016 10:31am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Pretty easy if I remember rightly, as you look in the engine bay from the front its kindof to the right of the centre of the engine at the front. Look for a big metal tube connected to rubber water hoses about the same size and shape as the new thermostat you will get.
Post #395547 11th Jul 2016 7:10pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
same year as mine easy job took about half hour on mine . Think it was some american bloke i watched doing it step by step online v good will try and find it Thumbs Up
Post #395552 11th Jul 2016 8:13pm
