Home > Technical (L322) > Broken wheel nut
Page 2 of 3 <123>
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
sounds like a plan
Post #388231 22nd May 2016 7:22am
p38arover
Australia
rar110 wrote:
My plan unless someone has a better idea is to angle grind a cut/slot at the top of the nut and use a cold chisel to split off the alloy cap. Then use a stillsons to get the nut off.
Isn't it still a hex head under the cover? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #388236 22nd May 2016 10:10am
Angle grinder that close to the wheel sounds like a recipe for disaster..... I'd try with just a chisel first.
Post #388237 22nd May 2016 10:12am
rar110
No idea Ron what's under the alloy cap.
I'll be able to do quite a bit with a thin blade grinder before getting close to the wheel. Then maybe the dremmel, then a hammer & chisel. ______________________________
Post #388239 22nd May 2016 10:54am
Lost for Words
This is what's underneath:
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #388240 22nd May 2016 11:14am
rar110
Thanks, so what holds the cap to the wheel nut? ______________________________
Post #388243 22nd May 2016 11:28am
Rust apparently Shocked 2008 MY Supercharged
Post #388245 22nd May 2016 12:11pm
Lost for Words
They're crimped into the groove above the flange:
With the ones I've had trouble with so far, I've managed to wangle the cap off and use a 21mm socket. Thumbs Up Visiting from DISCO3.CO.UK
Post #388247 22nd May 2016 1:00pm
Lost for Words
Oh, and IME, they still swell when the impact wrench is avoided. Rolling Eyes Visiting from DISCO3.CO.UK
Post #388248 22nd May 2016 1:02pm
rar110
Thanks again. I should be able to lever it off. These incidents are a PITA, but better happening at home than beside the road somewhere. ______________________________
Post #388274 22nd May 2016 8:37pm
rar110
Well I'm on my 2nd attempt to fit some new wheels. Now the locking wheel nuts on two wheels seem to be broken. The outer part on the nut is spinning but not undoing. I haven't used a rattle gun this time, just the wheel brace.
I've sprayed some penetrating oil in to try to save the situation. I'll leave it overnight. Any other suggestions? ______________________________
Post #394095 2nd Jul 2016 7:00am
Lost for Words
Argghh! http://www.disco3.co.uk/forum/topic68161.html Suggest you replace them with normal ones once you've got them off. Thumbs Up Visiting from DISCO3.CO.UK
Post #394160 2nd Jul 2016 5:36pm
rar110
Thanks mate. Some good suggestions on the D3 forum.
What should I replace them with OEM alloy capped nuts or go to aftermarket steel nuts? ______________________________
Post #394196 2nd Jul 2016 9:52pm
rar110
Well I've wasted most of today trying to get the two wheel nuts off. With no success.
The penetrating oil overnight had no effect.
I cut and chiseled of the nut caps.
I had about 4 attempts at mug welding a 12 mm bolt to the steel part of the nut. The weld broke 3 times. I gave up when I snapped off the head of the bolt.
Post #394226 3rd Jul 2016 9:23am
you can buy wheel nut sockets that have a screw thread inside them...you turn the socket anti clockwise and the thread bites into the damaged nut and undoes it.. ... - .- -.
Post #394230 3rd Jul 2016 9:38am
Page 2 of 3 <123>
