Home > Technical (L322) > Gap question
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Gap question
Hi guys,
Raised my suspension this afternoon and thought that it looked lower on the near side rear! Out with measuring tape and I have 34.5 " near side and 35" offside!
Ground to bottom of the wheel arch !
How do I lift it that .5 using my gap tool? I'm still quite nervous using it in case I screw it up and going on holidays next week!!
I looked at "height" and there are four arrows!
What's next??
Thanks in advance
David 2014 vogue se
Post #388255 22nd May 2016 4:40pm
i'd run it for a few days chef and go through the heights modes couple of times...when measuring again make sure its on an absolutely flat surface.. ... - .- -.
Post #388257 22nd May 2016 5:03pm
chefkenmore
Thumbs Up Bow down Thumbs Up Thumbs Up 2014 vogue se
Post #388259 22nd May 2016 5:14pm
Mikey
Bear in mind the acceptable height difference is 9mm per side, which easily accounts for that missing 1/2" Thumbs Up
Post #388271 22nd May 2016 8:15pm
chefkenmore
Cheers Mikey,
You were my next call!!! Thumbs Up 2014 vogue se
Post #388281 22nd May 2016 9:07pm
Mikey
If its not massively noticeable, I wouldn't be too concerned. You can spent hours re-doing the calibration to get it absolutely perfect, for not much benefit
In addition, the air compressor gets a hard work out with constantly adjusting heights and replenishing the air reservoir
Post #388290 22nd May 2016 10:12pm
Eirik34
Norway
Hi David, I guess you used the Gap EAS Calibration Aid (http://www.gap-diagnostic.com/wordpress/we...on_Aid.pdf) and looked at the sample EAS calibration sheet (http://www.gap-diagnostic.com/wordpress/we...lation.pdf) provideb by Gap? If not, I would recommend to use these. When I adjusted the height on our ffrr, I used these sheets to get it right.
Post #388294 22nd May 2016 10:58pm
