|  | Home > Technical (L322) > Gap question |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | i'd run it for a few days chef and go through the heights modes couple of times...when measuring again make sure its on an absolutely flat surface.. ... - .- -.
|  22nd May 2016 4:03pm |
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766      |
|  22nd May 2016 4:14pm |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | Bear in mind the acceptable height difference is 9mm per side, which easily accounts for that missing 1/2"   | ||
|  22nd May 2016 7:15pm |
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766      | Cheers Mikey,
|  22nd May 2016 8:07pm |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | If its not massively noticeable, I wouldn't be too concerned. You can spent hours re-doing the calibration to get it absolutely perfect, for not much benefit
|  22nd May 2016 9:12pm |
| Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443    | Hi David, I guess you used the Gap EAS Calibration Aid (http://www.gap-diagnostic.com/wordpress/we...on_Aid.pdf) and looked at the sample EAS calibration sheet (http://www.gap-diagnostic.com/wordpress/we...lation.pdf) provideb by Gap? If not, I would recommend to use these. When I adjusted the height on our ffrr, I used these sheets to get it right. | ||
|  22nd May 2016 9:58pm |
| Posting Rules
