Home > Maintenance & Mods (L322) > Bonnet Release Cable
Realist
Wales
Ahhhhhhhhhhhhh
Went to open the bonnet this afternoon to check the oil and type ready for a service and work being done this weekend coming and guess what.....................
The bloody bonnet cable has which I presume snapped and I'm unable to open the bonnet.
Any clues or do I have to employ a small monkey from Halfords monkey rentals to fix it Smile
Laters
PS, Anyone with a part no available? Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #388357 23rd May 2016 5:42pm
http://www.fullfatrr.com/forum/topic37041....nnet+cable
http://www.fullfatrr.com/forum/topic29319....nnet+cable
http://www.rangerovers.net/forum/6-range-r...e-how.html
should help Thumbs Up ... - .- -.
Post #388358 23rd May 2016 5:46pm
Realist
Wales
What would I do without my Stan Smile
Thanks mucka and I presume the part no for that 2005 is the same for a 2007? Range Rover quotes.....
Post #388359 23rd May 2016 5:49pm
Realist
Wales
Just did a Google search for FPF500010 and its the same.
Thanks Stan. Range Rover quotes.....
Post #388360 23rd May 2016 5:51pm
Post #388362 23rd May 2016 6:02pm
RR2008HSE
Happened to me too, a while back. Rather annoying, isn't it?
Post #388377 23rd May 2016 7:52pm
Realist
Wales
Annoying ummmmm too right. Range Rover quotes.....
Post #388379 23rd May 2016 8:07pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Just spotted this in the for sales, after reading your thread:
http://www.fullfatrr.com/forum/topic34738.html
Post #388421 24th May 2016 7:53am
Realist
Wales
Spotted that as well but already ordered a new one.
Thanks bud. Range Rover quotes.....
Post #388489 24th May 2016 3:02pm
Realist
Wales
Ok, just had 5 minutes and had a look at the bonnet cable. When I pull the handle I feel resistance like it's connected to something but the bonnet will not open.
The cable I ordered as above looks like it's not long enough to reach the front bonnet hole area so is the cable from the handle going somewhere else?
Stuck. Range Rover quotes.....
Post #389135 28th May 2016 8:51pm
The cable is in two pieces, there is a joint half way down the drivers inner wing... Thumbs Up Pete
Post #389136 28th May 2016 9:13pm
Realist
Wales
So I presume I have to remove the inner wing cover to access this join. Range Rover quotes.....
Post #389138 28th May 2016 9:46pm
No sir, its accessible from under the bonnet Thumbs Up
Post #389145 28th May 2016 10:04pm
Realist
Wales
So how am I going to access it if I can't open the bonnet? Range Rover quotes.....
Post #389149 28th May 2016 10:34pm
It usually breaks inside the car, the resistance you can feel could be the return spring... take it apart inside and see if you can find the end of the cable, get some pliers and give it a good tug....... Thumbs Up Pete
Post #389153 28th May 2016 11:14pm
