|  | Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | @RRBlue
|  17th Jun 2014 1:20pm |
| rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283      | how much new brake fluid did it take in the end after bleeding the system..? | ||
|  18th Jun 2014 10:56pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Actually not much, I used @ 1.5 litres in all, but I did go round three times in order to get as much new fluid into the system as possible. You don't want to drain the master reservoir if possible otherwise you can end up with air in the ABS modulator that you can't get out. But I was getting nice clean fluid out of all four corners before I finished off. .
|  19th Jun 2014 1:06pm |
| rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283      | Thanks,going at this tommorrow so didnt want to be buying to much fluid   | ||
|  20th Jun 2014 7:11am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Have fun, let us know how it goes, any differences on a V8 etc. .
|  20th Jun 2014 10:11am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Great work rathbranV8   | ||
|  29th Jun 2014 3:49pm |
| rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283      | No I used the Sealey pipe flaring tool AK5063.I couldn't get the tool you used delivered quickly enough even though it looks the business and easier to use.The tool I used is exactly the same as the one in the second half of this youtube clip approx 20 mins in.
|  30th Jun 2014 12:55am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Ah yes, I tried one of those to begin with, had so many failures I gave up, so well done for persevering   | ||
|  30th Jun 2014 4:34pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | Joe- mine has failed the MOT today on the rear pipes. Both flexis and the front to rear. I heard a while back that the fuel tank and driveshafts have to be dropped out to replace the pipes but you don't appear to have done that I see.
|  24th May 2016 11:57am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | You don't need to drop the fuel tank, just the plastic cover to get at the pipes. Never heard of the drive shafts having to come off?
|  24th May 2016 11:06pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | There's a YouTube "how to" and the mechanic bloke reckons the tank has be dropped. Had me worried for a minute there!
|  24th May 2016 11:09pm |
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492      | I did mine last year as preventative maintainance following joe's guide which was invaluable. The rears run from inside the N/S front wheel arch to the flexible fuel lines in one run. Once you get the covers etc off with some fiddling of the exhaust heat shield for the fuel tank cover its a straight forward job. I would say that I would think it would be much easier using the copper, or even better cupro nickel brake lines, to be bent to shape as there are some tricky spots to feed it through, especially on the rear o/s one. You will need a flaring too but the pre bent steel ones would be really fiddly to manoeuvre and you would need some real space to do it. Plus the copper ones or even cupro nickel would cost less aswell!! | ||
|  25th May 2016 6:54am |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | Can you clarify-  the rears have a flexi from the brake calipers with piped sections? The parts image looks that way.
|  25th May 2016 7:55am |
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492      | Yeah there is a flexi which is black rip über pipe and some metal that connects to the calipers then a bracket which is where the brake lines connect too them. If you get the car up on stands in full height mode and the wheel off the back you can get a good view of what's going on. With the lines once all the covering is removed and you get under there you can easily see where they run. It's just a case of feeding them through up to the flexis with the copper etc you can form bends easy enough by hand so being pre bent on the originals really isn't much of an advantage. Plus they could rust again and need doing once more | ||
|  25th May 2016 8:22am |
| Posting Rules
