Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines
Page 3 of 5 <12345>
Andy
The advantage for me is having the ends pre-flared with the fittings also added. Plus the front to rears are only £15. The flexis in the other hand are £82 each!
I replaced the fronts with genuine pre-shaped last year and they were a biatch to route around the back of the engine!
Post #388568 25th May 2016 9:31am
The guy in the video is talking OOHA about the rear pipes route. He probably means tank cover as I previously said.
The front to rear pipe for the RHR should be one piece, and L shaped of @ 7ft long by 3ft. It will go in but you need the space below the car to get it there (and no side step brackets in the way) .
Post #388619 25th May 2016 5:58pm
Britpart do rear flexis for £15 each, they are good quality and fit perfectly.. they also have no moving parts and that's my reasoning for going non genuine...
Any part that has to move or measure something then I go genuine... if it just sits there.... non genuine... there are always some exceptions... Thumbs Up Thumbs Up Pete
Post #388623 25th May 2016 6:27pm
Andy
Well I tackled mine today. I bought the front to rear pipes from Land Rover (£26 for the two) and 2x britpart flexis from Island 4x4 at £18 each
Surprised at how easy it was once all the covers were off. N/S front to rear was a doddle. I managed to get the O/S fitted without cutting the pipe. Took two of us to do it- one to guide and one to push/pull etc. The trick with the O/S pipe is to thread it down the chassis first, then pull back gently on the across chassis section of pipe, then feed it up and over the subframe.
Main dealer technician reckoned it was impossible without a ramp. That told him!
The existing ones were proper corroded. Given its done 133k in 15years they've done well I suppose.
Retest Monday then good to go!
Post #390218 4th Jun 2016 7:58pm
kevinp
Giant thread resurrection I know Andy, would you still have the part numbers for the brake pipes by any chance? Thanks Kev.
Post #604639 24th Aug 2021 10:09am
Andy
I might have. I was given a spare one which is in the loft still in the bag. Give me a couple of days to get up there and dig it out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #604640 24th Aug 2021 10:15am
kevinp
Thanks mate. I'm in Telford so I could come and collect it if you wanted to sell it.
Post #604644 24th Aug 2021 10:37am
Andy
I only have the one so you’d have to buy the other one. I’ll get it out and we can sort something out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #604646 24th Aug 2021 10:54am
kevinp
Would be nice if it was for the right rear. Thumbs Up
Post #604647 24th Aug 2021 11:01am
kevinp
Any luck Andy?
Post #605104 29th Aug 2021 12:41pm
Bingo_123
Does anyone have the part nos of the front to rear brake pipes.
and i reckon you need 2 of these long pipes on each side.
thanks
Post #605722 6th Sep 2021 12:32pm
Both the pipes, for the rear left brake for the rear right brake, run down the left hand side of the car. There are no brake pipe runs on the right hand side .
Post #605791 6th Sep 2021 10:27pm
Bingo_123
Thanks Joe, got it now.
Post #605816 7th Sep 2021 9:01am
Bingo_123
quick question : Can steel pipes be joined with copper ones ? will it work or any ill effects ?
Post #666673 15th Jun 2023 2:02pm
As long as the flares and connectors match up.
I recently had to do this on my Volvo, passed MOT, no ill effects. .
Post #666686 15th Jun 2023 4:27pm
Page 3 of 5 <12345>
