Home > In Car Electronics (L322) > remoute control dont work for rear seat entertainment
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
I have a 2012 with RSE. This car has already the touch screan remoute control. But the remoute control dont work. I can swich on and control the two sreens from the front, but I cant control the screens not with the remoute control. The remoute is charget and out of the arm rest. The menue is there, but it wont change anything. The blocking botton on the front screen is off. I checked with a camera , and a red flash is visible when using the remoute. I wend to the dealer and there say, all rse otions are checked in. What can I do to find out what the problem is ?
Thanks Andre
Post #389630 1st Jun 2016 9:26am
mzplcg
Hi Andre
I had this on a 2011 car. What I found was that you must have the front screen NOT on the rear entertainment functions. If you are controlling from the front then the remote in the back will not work. It's like a parents lock kind of thing.
Set the front screen to be on the HOME screen, have the engine running and try again. It will probably work OK.
Gruß
Dom
Post #389638 1st Jun 2016 10:18am
Ahh you beat me to it Thumbs Up Bow down Thumbs Up
Post #389649 1st Jun 2016 10:36am
mjdronfield
I have the same issue, and re-read the manual that states the remote is locked out if the supervisory screen is showing in the front.
Not tried it since.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #389715 1st Jun 2016 5:51pm
capcgn
I try it and now it works............. Thank you for your tips.
Post #389787 2nd Jun 2016 8:25am
Realist
Wales
Well I be Censored I have this on mine and by golly thanks for the heads up Smile. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #389803 2nd Jun 2016 10:24am
