![]() | Home > LPG > MPG query |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8823
Think you added that's it's a 4.4 V8 on the wrong thread....
| BCM Member Since: 09 May 2016 Location: Manchester Posts: 2
Yeah I did, but once posted you can't delete! Thanks for the info and advice |
| Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55
I drive local most of the time, school run then to work etc
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2298
Sleeper that's nuts - I am consistently getting 75litres to 190miles - I took it to a specialist as I initially had a few problems and they pointed out the Ecu was from 2003 and did not have the don interface, the injectors were as old and were over fuelling and that it wasn't ideal as the gas was fed with a 6mm pipe not an 8mm I got the first too done so far and get that economy in my 4.4 v8 is yours the dme engine ? Wht kit do you have ? I have omvl/zavoli aeb |
Hiya
| mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311
Mine's a 2003 with a BRC system. In mixed driving I get about 250 miles on just under 70 litres, which I think is 15-16 MPG. I've only run it dry once, I think I got nearer 260 miles but can't remember how much it took to fill it! |
That pretty good - why s gas so cheap in birmingham was there yesterday and got .39 per litre although i noticed it was Callow Gas not Calor Gas! |
| SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457
mine does around 220 miles per 80 litre fill. |
| Riedland Member Since: 06 Oct 2015 Location: Far east Posts: 21
mine does up to 280 miles with 75L of lpg exactly the same mpg as my old classic but in this latter I can fill in 95 litre.
How can this range vary so much between vehicles? |
| steptoe Member Since: 23 Jul 2012 Location: london Posts: 382
It can vary hugely on the same vehicle |
Lucky Belgian lpg drivers, I was traveling in Belgium one month ago sadly not into one of my RR but in my 109, the cheapest filling station I saw was this one |
| Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409
I get 14.45mpg average, and used to do 17.76 on petrol - measured full tank to full tank since 2012.
That is cheap I was there two year back and it was 70cent a litre gone down a lot... If you know where to look here you can get it cheap I filled up in Birmingham on Tuesday for 39ppl |
| All times are GMT |
