Home > LPG > MPG query
BCM
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
MPG query
So I've had the beast a month now and I'm averaging 100-150 miles out of a full tank of LPG (70 litres/£35) which the LPG guys say is about right?! Really? And this is taking it easy I might add.
Post #386443 11th May 2016 5:30pm
Think you added that's it's a 4.4 V8 on the wrong thread....
You should be getting more than that, your getting between 6 to 9 mpg on those figures, you should get between 14 - 18 depending how you drive, which is about 20% less than petrol....
Very easy to make an LPG fueled car run nice by richening the mixture, find another garage and ask them to set it up properly, go on LPGA site to find a member....
Thumbs Up Thumbs Up Pete
Post #386455 11th May 2016 5:45pm
BCM
Yeah I did, but once posted you can't delete! Thanks for the info and advice Smile
Post #386509 11th May 2016 7:11pm
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
I drive local most of the time, school run then to work etc
i recon i fill up (90 litre tank) 80 litres (give or take a bit) at a cost of around £35 (at the moment as prices go up and down but at 43p per litre )and expect to get 240 miles to a tank.
i dont always drive like miss daisy but 240 give or take.
When i get on the motorway, say on a good run then 350ish
Post #389750 1st Jun 2016 8:41pm
Danwilderspin
Sleeper that's nuts - I am consistently getting 75litres to 190miles - I took it to a specialist as I initially had a few problems and they pointed out the Ecu was from 2003 and did not have the don interface, the injectors were as old and were over fuelling and that it wasn't ideal as the gas was fed with a 6mm pipe not an 8mm I got the first too done so far and get that economy in my 4.4 v8 is yours the dme engine ? Wht kit do you have ? I have omvl/zavoli aeb
Post #392464 21st Jun 2016 8:13am
Sleeper
Hiya
Mine a 2003 4.4 BMW Engine, not sure of the exact system but its prins (will check model later)
I recon it was fitted back in 2010-11 (before i brought th ecar)and i cannot remember all the details but the eloctronics were hardwired in, he changed them for plug and play, done loads of update etcI wrote a little bit about it here
http://www.fullfatrr.com/forum/topic37907.html
I cannot remember the exact milage but it will be around 240milel before the last two fill ups and the light was on red, so still some in there
27.05.16
83.5 litres
.38p per litre
£31.73 to fill up....Bargin!!
18.06.16
82.65 litres
.40p per litre
£33.06 to fill up....again Bargin!!
Post #392595 22nd Jun 2016 8:04am
mr_spock
Mine's a 2003 with a BRC system. In mixed driving I get about 250 miles on just under 70 litres, which I think is 15-16 MPG. I've only run it dry once, I think I got nearer 260 miles but can't remember how much it took to fill it!
Post #392614 22nd Jun 2016 9:55am
Danwilderspin
That pretty good - why s gas so cheap in birmingham was there yesterday and got .39 per litre although i noticed it was Callow Gas not Calor Gas!
Post #392626 22nd Jun 2016 11:42am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
mine does around 220 miles per 80 litre fill.
Post #392644 22nd Jun 2016 2:04pm
Riedland
France 2006 Range Rover Supercharged 4.2 SC V8 Java Black
mine does up to 280 miles with 75L of lpg exactly the same mpg as my old classic but in this latter I can fill in 95 litre.
This is the downside of the L322, not enough room for a decent lpg tank if you want to keep your boot free Sad
On long journeys the mpg can improve further more. Current:
- L322 2006 S/C lpg
- RRC 1988 lpg / 287 000 miles
- Stage one 1981
- Lightweight 1976
- 109 SW 1968 under rebuilt
Gone: none
Post #392672 22nd Jun 2016 7:00pm
Danwilderspin
How can this range vary so much between vehicles?
Post #392703 22nd Jun 2016 10:00pm
steptoe
It can vary hugely on the same vehicle Very Happy .
As always with a range rover, depends on where it's driven.
Driving in town (London) low MPG, outside town could easily be a 50% MPG improvement.
Post #392762 23rd Jun 2016 12:25pm
Riedland
Lucky Belgian lpg drivers, I was traveling in Belgium one month ago sadly not into one of my RR but in my 109, the cheapest filling station I saw was this one Shocked
 Current:
- L322 2006 S/C lpg
- Stage one 1981
- Lightweight 1976
Gone: none
Post #392807 23rd Jun 2016 7:28pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I get 14.45mpg average, and used to do 17.76 on petrol - measured full tank to full tank since 2012.
My driving is a mixture of motorway and local roads and I tend to make reasonable progress if conditions allow.
Most miles I've got from the tank is about 250, and most I've got in is 79l. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #392822 23rd Jun 2016 9:34pm
Danwilderspin
That is cheap I was there two year back and it was 70cent a litre gone down a lot... If you know where to look here you can get it cheap I filled up in Birmingham on Tuesday for 39ppl Wink I don't live near here but I will try and incorporate into long journeys if along the way now! Only 2miles off the m6 as well
Post #392832 23rd Jun 2016 10:29pm
