![]() | Home > Maintenance & Mods (L322) > L322 03 plate power steering fluid leek |
| Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55
Just replace it as soon as possible. But the mess it's caused |
| smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124
Will I need to flush the power steering fluid or will it be OK to fill up to the correct level with new? |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
Fix leak. Refill reservoir with new fluid to the correct level. Start engine and turn steering from lock to lock a few times to bleed the system. Stop engine, check for leaks. Top up reservoir with new fluid to the correct level. Check the level a week or two later to make sure it's still OK, top up again if necessary. |
| All times are GMT |
