![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 advice |
Yes check for "oil drain pipe modification" is a 10 hour modification requiring drilling the block at owners cost... |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
Wow, back to school with a thesis to read.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35694 ![]() ![]() |
this mod is only done if the FF needs it, it will not be done 'just in case'
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6791 ![]() ![]() ![]() |
So it's quite good then? |
Mactech Member Since: 27 Jun 2015 Location: Biddulph Posts: 126 ![]() ![]() ![]() |
Well @ rr driver...you did ask |
Yes, so just a little good then!
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Hi all, hope you don't mind me resurrecting this! I'm in the process of looking for a 4.4 at the moment. Has anyone got any idea how much this mod would cost if I required it? And what is the easiest way to identify weather it has been done or not?
it will cost around £1k..
because the 4.4 tdv8 is such a lazy engine most dont go over 2500 rpm when at those revs the second turbo kicks in...if and when you test drive , boot it so the revs go over that rpm and have a look in the rear view mirror for excess smoke.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3832 ![]() ![]() ![]() |
I had the turbo drain mod done in January.
Hi Mike, thanks for the reply. The car I am looking at buying, I took it for a drive today. There was nothing at tick over, I got the guy to rev it hard whilst I was stood behind and nothing either. I spank it a couple of times on the test drive and still nothing! I am hoping it is ok.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
If it's not smoking then I would be inclined not to worry about it too much.
