Home > Technical (L322) > L322 ride height
Mac1971
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
L322 ride height
Measure ride height from centre cap to wheel arch and I have 2" difference from front to back . 20" front and 18" back. Anyone had similar ? I believe correct heights are 20 3/4" front and 20" rear. Cheers
Post #391411 12th Jun 2016 7:23pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
From a member of another forum
Measure from bottom edge of wheel arch centre point to the bottom of the wheel rim straight through the wheel centre
18" wheels 741 f 731 r
19" 753 f 743 r
20" 767 f 757 r
Measured in mm at standard height
Post #391420 12th Jun 2016 8:23pm
from our forum,
Post #391438 12th Jun 2016 10:04pm
Mac1971
Thanks for info , looks like front to back diff is 10mm in normal height , anyone tell me how to adjust it as I have 50mm
Post #391441 12th Jun 2016 10:12pm
@ mac1971
Looks like you are too high at the front (508(20.75in) not 493) and too low at the back (457(18in) not 483)
Suggest keep checking for now, do some ups and downs with the heights, but may need setting with your All Comms or IID Tool Thumbs Up .
Post #391442 12th Jun 2016 10:15pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Thats very interesting!
Just rushed out to measure mine. Rear correct for 20inch wheels, front at the 19inch height.
I new something had changed after I had the tyres changed!
Cheers, Jerry THIS WRECKAGE
Post #391487 13th Jun 2016 10:48am
Road Stone
Okay I have taken measurements at all heights and basically I'm missing about 12mm from the front.
In other words the car is sitting almost level, front to rear.
It used to be okay but something has changed since I had the tyres changed (all four wheels were lifted of the ground at the same time).
Can anyone advise what is the best way to re set? I have Hawkeye but realised I need a differing cable, I think. My indie has Auto Logic.
Post #391564 14th Jun 2016 5:45am
