![]() | Home > Wheels & Tyres > General Grabber AT2 / AT |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
I’ve been very happy with the AT2’s I put on my Fatty when I bought it. Now, after 40,000 km (25,000 miles) there was still some 5-6mm of tread depth left (10 mm when new), but as the tyres are now nearly 7 years old and showing signs of cracking (from the hot Côte d’Azur sun, I suppose), I decided they needed replacing.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
interesting thread. I was concerned about noise hence going for the scorpions 2007 Vogue TDV8 with 255/55/20's fitted |
They don't howl at you... In fact I don't notice them at all..... unlike the Cooper STT's that are on my Jeep Jeep |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766 ![]() ![]() ![]() |
I've had mine on for over a year now and they're great !
When I first got my ffrr it had Scorpions on it and the rear 2 were shot...... having just handed over an arm and a leg, there wasn't much change in the kitty for tyres. So I was forced to fit 2 tyres to start with and keep the Scorpions on the front...... I ran for 8 months like that..... and then I finally got around to changing the front tyres to match the rear AT's..... the first time it rained I was a bit wary about the level of grip I would have compared with the Scorpions..... But to be honest I didn't notice any difference |
Ollie_247 Member Since: 26 Nov 2015 Location: Buckinghamshire Posts: 35 ![]() ![]() ![]() |
Hi All,
Thank Miggit that kind of what I was going for
Are...... you will get a problem with that Sir, sorry, I assumed that you were changing it for the same size.... I have a BMW ffrr and the wheels are 18", the tyre sizes were the same The replacement tyres were a little bigger cos they had more tread, but we are only talking a few mm's. Your proposing a 5% increase in size plus more tread, I don't think that your diffs will like you much for that, especially the central transfer box one..... which will more that likely throw it's toys of the pram and die |
unfortunately not they don't make them in 50 profile so will jump up a size. The MOT Track days Test Dummy
Well the car will handle the size increase with out any bother, but I would recommend the use of an after market sat nav (tomtom, garmin) to check the speedo readings.... best way is to employ cruise control on a flat bit of ground and compare the dash to the sat nav.
Seem after a bit of googling as I was just about to order four, This very forum showed up another size I total missed
