Home > In Car Electronics (L322) > Blue tooth telephone module upgrade
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Morning All,
I have a FFRR 3.6 TDV8 that I brought about a month ago - superb car - save for the Bluetooth.
I have had some email exchanges and understand that there is a newer unit about that will store the pairing info and contact numbers but that it needs a wire or two added to instal it, and therein lies the problem, wiring and I are not the best of friends.
Does anyone know where i could get one installed or has done one previously - I dont mind paying, its just that I spend a lot of time in the car and the blue tooth needs sorting.
Cheers
Mick
Post #392596 22nd Jun 2016 8:17am
I'm sure a local member will be able to help, it really doesn't take long, the longest part is getting the correct two power cables out of he old loom and into a suitable connector and then mounting the new unit. Personally I used electrical tape to secure it down and haven't had any issue with it since as its been the best upgrade other than the audio upgrade I did 😊👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #392738 23rd Jun 2016 9:44am
You can try a flash update performed on your existing module first... May not need replacing???
Post #392741 23rd Jun 2016 9:53am
^ I did that on mine using my IIDTool when it didn't see my iPhone 5. Got - 2017 SDV8 Autobiography in Loire Blue
Post #392743 23rd Jun 2016 9:55am
Busa1400
I spend to much time in the car that I need this Bluetooth to be right, driving along with Apple headphones in just seems wrong in a RR.
I have arranged a clandestine meeting at 06:45 Friday morning Very Happy Very Happy when the Guru will fix the same. 2011 Range Rover Vogue SE
Post #392754 23rd Jun 2016 11:01am
I've done the firmware update and then the replacement from the later Range Rover/discos.
Speaking from experience it's better to do the job once and do the straight move instead of just doing the firmware update Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #392755 23rd Jun 2016 11:10am
Busa1400
Just to say that Bluetooth exchange came out as expected at silly o'clock in the morning and a nicer chap you could not hope to meet, very quick installation and very very knowledgeable, I am sure you all know this already, but just passing on my gratitude to a great guy.
Thankyou Sir 2011 Range Rover Vogue SE
Post #394166 2nd Jul 2016 7:06pm
