![]() | Home > In Car Electronics (L322) > Blue tooth telephone module upgrade |
I'm sure a local member will be able to help, it really doesn't take long, the longest part is getting the correct two power cables out of he old loom and into a suitable connector and then mounting the new unit. Personally I used electrical tape to secure it down and haven't had any issue with it since as its been the best upgrade other than the audio upgrade I did 😊👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
You can try a flash update performed on your existing module first... May not need replacing??? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
^ I did that on mine using my IIDTool when it didn't see my iPhone 5. Got - 2017 SDV8 Autobiography in Loire Blue
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
I spend to much time in the car that I need this Bluetooth to be right, driving along with Apple headphones in just seems wrong in a RR.
I've done the firmware update and then the replacement from the later Range Rover/discos.
Just to say that Bluetooth exchange came out as expected at silly o'clock in the morning and a nicer chap you could not hope to meet, very quick installation and very very knowledgeable, I am sure you all know this already, but just passing on my gratitude to a great guy.
