![]() | Home > Technical (L322) > no heater blower |
Turnover Member Since: 27 May 2014 Location: Norwich Posts: 39 ![]() ![]() ![]() |
Hi, have you got any photos you can share as I'm in the middle of this without much of a clue and some very sore hands. ![]() Cheers Chris 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather |
Hi has anybody else carried out this repair on a 2007 or later L322? I'm interested in finding out how to get to the fastening catches on the blower motor case. It is still buried after stripping most of the dash out. I can see the motor housing but the top, where one of the catches sits, is covered by some trunking full of cables. The sides of it are equally hidden. I feel I'm so close but so far away....
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
Very nice description, delighted to not have to spend 14 hours in the garage...
Hi, I'm not sure what to suggest as I have made the decision now to get it sorted at our local indie. The frustrating thing is that I can see and move the motor around but the gap is too small to get it out. There is a bit of trunking containing a big wiring loom that runs across the top of the motor housing that prevents access. |
largeone Member Since: 27 Sep 2015 Location: Nottingham Posts: 3 ![]() ![]() ![]() |
Hi all.
Hi, my one was not really free but would move. The new one I have bought spinned much more easily. I don't know where the feed is for the back ones so cant help with that one. Cheers 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather |
I've just changed the fan a few minutes ago, more info will follow shortly.
After uncovering the holy grail, my Fein Multimaster had to do the next job.The finished cut is visible here:
SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 17 ![]() ![]() |
Thanks for the write up, helped a lot.
MrSteed Member Since: 04 Nov 2018 Location: Florida Posts: 2 ![]() ![]() ![]() |
I just completed putting in a new blower motor in my 2009 L322, left hand drive US version. Just want to let everyone know you don’t have to cut any part of the Dash (or anything for that matter) at all. There is plenty of room to get the new motor in and out. It really wasn’t that bad, just take your time and label all the screws in baggies. One tip, for the vent tube that goes towards the passenger window, there’s an accessible torx screw to remove in the middle of the vent tube. Take your torx screwdriver and find the head of the screw with your fingers. Removing that securing screw allows you to completely move that vent out of the way giving you plenty of room. You do need to remove the CD Changer to get to that screw. The thing that gave me the most trouble was removing the metal rod from the flap (the above poster mentions), then getting it back on. I did damage the part that secures it but it should still function fine. Many thank to those who contributed to this thread - you all saved me a ton of money! |
MrChubba Member Since: 03 Dec 2017 Location: Penrith, Cumbria Posts: 4 ![]() ![]() ![]() |
MrSteed,
Mine looks a bit different to yours, I don’t seem to have the space you have at the bottom of the plastic surround. So, I think I need to cut despite removing the flapper assembly |
Pavetim Member Since: 02 Sep 2019 Location: Valdosta, ga Posts: 23 ![]() ![]() ![]() |
Can you change the blower from the top on a 2010 RR full size? Mine looks different than these pics here. |
