![]() | Home > Maintenance & Mods (L322) > Replacing transmission sump gasket |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 ![]() ![]() ![]() |
Someone was probably having difficulty getting it to seal ! |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Nope,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8691 ![]() ![]() ![]() |
When you have it off check it is level and not distorted, they can swell around the holes if some buffoon has been at it...
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Tar for the reply. I used swarfega driveway cleaner on mine, seamed to work quite well when combined with hot water and a stiff brush. |
If a buffoon has been at it, would it be wise to use sealant then? I have all genuine zf bought from jpat. Am changing the wiring harness for the oil temperature sensor too, think it might be called a valve body harness.
Virtually impossible to get it to seal with sealant, the autobox oil tends to eat most things and it will leak eventually unless you use a polyurethane sealer like tiger seal, in which case you will have a job getting it apart again... You will also have to fit the sump, then leave it a day for it to harden before filling...
Thanks for the feedback. Yeh I have read up on the oil, got my shipment of mobil this morning, just waiting for the mini pump to arrive and get a new t27 bit and am good to go. Fingers crossed they haven't used that tiger seal on the sump though. The place I bought the vehicle from said it looked like it had a new transmission on it but there was no paperwork to confirm that. I suppose there might be a date stamp on the transmission somewhere. |
They date stamp the genuine gearbox filters... Pete
Run into a snag. Looks like pan has been off before and one of the pan bolts has either corroded or been rounded off so the t27 bit won't grab onto it.
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 ![]() ![]() ![]() |
're your question on removing oil from your driveway,I read somewhere that using Head n Shoulders shampoo,brushed onto it and left for a while before rinsing off.Sounds daft and I've not tried it myself but its worth a try. |
Got the bolt out! |
