![]() | Home > Maintenance & Mods (L322) > Replacing transmission sump gasket |
| Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48
Someone was probably having difficulty getting it to seal ! |
| ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94
Nope,
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
When you have it off check it is level and not distorted, they can swell around the holes if some buffoon has been at it...
| smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124
Tar for the reply. I used swarfega driveway cleaner on mine, seamed to work quite well when combined with hot water and a stiff brush. |
If a buffoon has been at it, would it be wise to use sealant then? I have all genuine zf bought from jpat. Am changing the wiring harness for the oil temperature sensor too, think it might be called a valve body harness.
Virtually impossible to get it to seal with sealant, the autobox oil tends to eat most things and it will leak eventually unless you use a polyurethane sealer like tiger seal, in which case you will have a job getting it apart again... You will also have to fit the sump, then leave it a day for it to harden before filling...
Thanks for the feedback. Yeh I have read up on the oil, got my shipment of mobil this morning, just waiting for the mini pump to arrive and get a new t27 bit and am good to go. Fingers crossed they haven't used that tiger seal on the sump though. The place I bought the vehicle from said it looked like it had a new transmission on it but there was no paperwork to confirm that. I suppose there might be a date stamp on the transmission somewhere. |
They date stamp the genuine gearbox filters... Pete
Run into a snag. Looks like pan has been off before and one of the pan bolts has either corroded or been rounded off so the t27 bit won't grab onto it.
| LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54
're your question on removing oil from your driveway,I read somewhere that using Head n Shoulders shampoo,brushed onto it and left for a while before rinsing off.Sounds daft and I've not tried it myself but its worth a try. |
Got the bolt out! |
