Home > For Sale & Wanted > [SOLD] Second battery system for L322
docjones
Finland
Selling my second battery system that was built for our Iceland trip. The car is now gone and the system is surplus to my requirements.
Replaces the right side panel in the trunk and is basically plug&play. Does not include battery.
Basic layout is CAR<->CHARGE RELAY<->2nd BATTERY<->LOADS. Both car and loads can be isolated independently from the system through two heavy duty isolation switches. Charge relay will ensure that any loads can not run the main battery empty. All loads, ie. 12V socket, USB sockets, inverter feed, have their own fuses as well. The whole system has 80A fuse towards the car to prevent issues, since the cable between trunk and main battery is officially rated at 100A.
Panel also has it's own voltage display and depending on two way switch position, will display either car or second battery voltage. All cables are heavy duty silicon cable and are sufficiently large to handle rated loads. No exposed pins or other voltage sources as everything is behind the panel face. Also all the switches have been installed so that they are sufficiently deep inside the panel preventing square items hitting them inside the trunk. Lower panel also has space for inverter with feed cables in place.
Asking for 120GBP with shipping.
Please ask if you have any questions.
DJ
Post #396110 14th Jul 2016 8:13pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Where would the second battery be situated and what maximum or minimum rating would the battery have, please?
Post #396127 14th Jul 2016 10:39pm
docjones
Finland
Hi,
There is perfect space for second battery underneath the panel. It is usually occupied by storage bin which is replaced with second battery. See: http://www.fullfatrr.com/forum/topic5721.html
I had a 60Ah Varta battery in the space, but it can accomodate batteries up to 90/100Ah.
DJ
Post #396130 14th Jul 2016 11:01pm
I got a Varta Silver 110AH (main battery) in the cubby, needed to saw off the plastic surrounds (on the battery) and cut out a screw thread that was sticking up. Tight fit but it goes in. .
Post #396134 15th Jul 2016 12:08am
Giantlandyman
Thank you, docjones & Joe90.
Post #396161 15th Jul 2016 8:59am
dhallworth
Just to point out if you've got the removal tow bar stored under there the battery won't fit under that panel. Smile
I'm tempted by this for no other reason then it'd let me watch the TV or a DVD in the FF whilst the other half goes shopping without worrying about the battery Laughing
Post #396305 15th Jul 2016 11:53pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Doct
where did you terminate -ve and what wwe'rethe bare ended cables connected toon the bottom left in the 2nd pic?
Post #396323 16th Jul 2016 7:51am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
PM sent Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #396347 16th Jul 2016 12:09pm
docjones
Finland
nbunney wrote:
Doct
Hello nbunney,
there are several places where you can terminate the ground cable inside the trunk. I used 7mm bolt in the lower part of d-pillar. Bare ended cables were for 300W inverter I had installed there. These cables can simply be removed or fuse taken out if no inverter is installed.
DJ
Post #396466 17th Jul 2016 11:56am
docjones
Finland
Hi,
Item has now been sold. Thanks for everyone interested.
DJ
Post #396504 17th Jul 2016 6:54pm
