Home > For Sale & Wanted > [SOLD] Second battery system for L322 |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Where would the second battery be situated and what maximum or minimum rating would the battery have, please? |
14th Jul 2016 10:39pm |
docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48 |
Hi,
14th Jul 2016 11:01pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
I got a Varta Silver 110AH (main battery) in the cubby, needed to saw off the plastic surrounds (on the battery) and cut out a screw thread that was sticking up. Tight fit but it goes in. .
15th Jul 2016 12:08am |
Thank you, docjones & Joe90. |
15th Jul 2016 8:59am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
Just to point out if you've got the removal tow bar stored under there the battery won't fit under that panel.
15th Jul 2016 11:53pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Doct
16th Jul 2016 7:51am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
PM sent Tom
16th Jul 2016 12:09pm |
Hello nbunney, there are several places where you can terminate the ground cable inside the trunk. I used 7mm bolt in the lower part of d-pillar. Bare ended cables were for 300W inverter I had installed there. These cables can simply be removed or fuse taken out if no inverter is installed. - DJ |
17th Jul 2016 11:56am |
Hi,
17th Jul 2016 6:54pm |
